Since I do the maintenance for all our vehicles myself, oil changes get to be a headache/mess at times with multiple vehicles.  After reading a post or two in the past (I believe one was on this site) about Fumoto Oil Drain valves, I decided to pick a few up to see how well they work long term.  I do have some questions though and I was wondering if anybody might be able to answer them through experience.
1.  Any internal seal issues with the valve over prolonged periods of usage (75K+ miles)?
2.  Any internal seal issues with the valve when going from extreme cold to engine operating temperature (Usage in Alaska and Canada)?
3.  Any issues with the valves contacting the ground or obstacles when off road driving?
I'm kinda excited about giving them a try and I expect there to be no real issues, but I would just like to be aware of any known issues so that I can prepare for them accordingly.
I've been using Fumoto drain valves in a variety of vehicles for decades now and I've never had a single issue, whether during Alaska winters or Arizona summers.  I don't off-road my truck, so I can't speak about clearance issues.  My Jeep is armor-plated underneath, so the Fumoto is well protected.  I would cover with a skid plate if doing any serious off-roading.
I've got one on my LS3 Equipped SS Sedan.  Never leaks, no issues with weather or hitting things on the ground whatsoever.
Awesome, thats the kind of information I was hoping to get, thanks!
I almost purchased a Chevy SS before purchasing the truck.  I was a gnat's ass hair away when that family bug started buzzing in my ear some ridiculous nonsense about needing more room and cargo space for kids sports, camping, etc.  I don't regret the choice to go with the truck, but dang, the SS is the last 4 door sedan with a RWD V8 and manual transmission from GM....slightly jealous 😃
So in a round-about way you're asking if your oil were to drain out while driving down the highway would you be SOL and buying a new engine?
The answer is yes.
I had one on my 2002 Silverado for over 200k miles no issues.  Sure makes hot oil changes easier.  Like pulling in the driveway right off a long 4hr drive down the interstate and up on the ramps and under it to open it up and let the hot oil out.
I would like to add...get the one with a nipple.  That way you can attach a length of clear vinyl tubing that reaches the oil drain container.  Otherwise it will splatter, just like it does when you remove a drain plug.
I did.  I ordered three valves with the small oil drain nipples and one plastic hose with the two fittings.  I'm sure I'll lose that hose in no time flat, but hopefully not. :)
I was thinking about one of these as well...have heard good things.....
I've used a fumoto valve on my current truck for over 100,000 km. Best thing I ever did for vehicle maintenance. It makes oil changes so much easier and less messy.
I have the nipple on mine & just run a length of rubber hose from it into a 10 liter jug to catch the old oil.
2 hours ago, puppykat33 said:
Here is some new black magic
give this a try i have heard lots of satisfied customers on the camaro forum
https://www.valvomax.com/
Thanks for the heads up.  I've already received 3 of the Fomoto valves and will be swapping them out on the next oil changes.  However, if I have any difficulty or issues with them Ill check out the valvomax.  Thanks again for the heads up.
No mention of how you change out the oil filter.  Oh yeah, you still need an oil drain pan after all.  And that flimsy paper funnel.  What a joke.  I anchor my oil funnel to the windshield wiper with one of those tiny bungee cords I thought I'd never use.  That way it doesn't move around as I'm pouring from a five quart jug.  Valvomax may look appealing...until you actually use it.
    DLZ
    DLZ
  • Who's Online   5 Members, 0 Anonymous, 629 Guests (See full list)
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
