Hey guys, need some serious help... I was revving my engine on my 2008 Silverado and heard what sounded like a fuse popping from the dash and now my shift indicator doesn't show which gear I'm in and my reverse lights do not illuminate. My odometer works fine, and the gears are illuminated, just not the square that highlights which gear I'm in. It's not even highlighting the P when in Park. It's just gone. The truck cranks and drives fine other than that, you just have to feel for which gear you're in. I've just changed out the Neutral Safety Back-Up Switch on the side of the transmission thinking that was the culprit, but no change. I've gone over every fuse and relay. Something else odd is that there's a loud relay-like clicking sound coming from my steering column now when I press the brake, which wasn't even noticeable prior. I called a cluster repair service to see if that maybe the problem and they said my cluster is fine, that it's my shift indicator sensor. I have no idea what that means, as I can't find any part on my truck named that, unless he was referring to the NSBU sensor. Any help would GREATLY be appreciated. I'm losing my mind over this.
Well I finally figured it out! Even though my check engine light wasn't on I decided to hook up a diablo tuner I bought for my wife's suburban to see if there were any codes. I was able to see a logged code: P1818 - Transmission Fluid Pressure Valve Position Switch-Drive Without Drive Ratio. It appears that the truck enabled a some sort of safety to protect the transmission while I was revving it. After clearing the code my shift indicator returned, my reverse lights now work, and the clicking in my steering column when pressing the brake has disappeared. I took it for a test drive and all is well!
Thats cools you figured it out.  I had nothing to offer. I was going to ask why you were out reving the engine, but decided not to.  In my mind I pictured someone reving the motor to 4900 for a few minutes then letting off, doing that over and over again, pissing the neighbors off.  In my head it was Karma, but I am glad that isnt what happened.
Haha, definitely not what was happening. This is my farm truck and it doesn't get used too much. I cranked it up (which it barely did because of sitting for so long), added some Liqui-Moly Jectron to the tank to clean the injectors and was trying to burn through it real quick and send more juice to the battery at the same time.
Edited by delta task1
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
