My GMC Sierra has over 200k miles on it and I’ve been using 5w-30 synthetic oil as I always has and recently I’ve noticed a very small leak in my oil. Would it be smarter to start using 10w-30 or 10w-40 because my trucks many miles or just stay with what I’ve been doing?
 By calling it a leak you have oil on the floor or coating your engine externally? Changing oil viscosity is very unlikely to stop a leak at a seal or gasket. Best to fix the offending part.
If you're burning, consuming oil internally to the engine, then viscosity might make a difference
Like txab said, mechanically leak, ie bad/worn seal can't be fixed by a different grade oil.  Best to find it and replace the part that is leaking.  My 2002 started to leak at 170k and it was the rear main seal.  Once that was replace it was back to a nice and dry engine and undercarriage.
If it is burning oil and no evidence of exterior leak then a higher viscosity might help slow it down.
If it is a seal in a motor with that many miles on it a band-aid fix MIGHT be a high mileage oil. Sometimes a seal will weep when it is loosing elasticity and a high mileage oil will swell the seal a bit slowing or even stopping the leak for awhile. How long is a while? :dunno: A gasket may be cork, composite, rubber, synthetic and may respond to the same thing but less likely to do so.
Even replacing a seal on a shaft with that many miles may not solve the issue IF the shaft is also worn. Depending on where, a 'Speedi Sleeve' will often do the trick. If it worn past that parts replacement or repair will be required. It's near impossible to get a new seal to seal on a worn shaft no matter how well you prep it.
After all that....repair is a better solution. Heavier oil will do nothing meaningful.
you might want to look into your oil pressure sensor, when they are on the down side they can leak oil, its discrete at first, and will be toward the firewall side.  Put your hand back behind the engine and see if you have oil slick residue back there, then change it out before changing oil types.
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
    • Knowing the life of your brakes is a highly important status to keep track of. If you suspect your brake sensors need attention, please fill out our support form with additional details on your experience. When did you last take it in for inspection? Our team will follow up with next steps as soon as next available. Please include your username and GM Trucks Forum in the form as well. Support Form: https://s.chevy.com/support-request
