Hi All - former owner of the other brand, I have an opportunity to buy a 2020 Denali w/ 6.2L and 60k miles.  I am trying to learn as much as I can about the GM platform as this is my first GM.  Wonderful forum here.
I'm struggling to find anything that says "I have 100k+ miles on my MagneRide suspension".  How reliable is Magneride?  Everything I'm reading relates to Magneride failures and people swapping Magneride for more traditional suspensions.  It is just assumed that MagneRide needs to be replaced every 50-60k?
Looking for any comfort that MagneRide is worth it and is not an absolute pain in the rear.  I keep trucks for a long time and would hope to drive this one for 200k+ miles but if its going to cost $3-4k every 50k miles, I might go another direction.  Fwiw my current daily driver I bought 20 years ago, summer of 2001, to give you a sense of my ownership style.
Thank you in advance for any help!
I wouldn't have a truck with that system. $$$$
To me, the Magneride in the Tahoe/Suburban/Yukon ride no different than one without it.  You don't get to really see how Magneride makes a difference until you step into a Corvette or Camaro with it.  On those you WILL notice a ride difference between touring, sport and track.  There's no modes on the 2020 and older SUVs to alter the ride.
I would get a Yukon without it as its $$$$ to maintain it.  The shocks and struts in the SUVs are lucky to get past 50k.  A Camaro or Corvette?  Totally worth it.
Edited by newdude
3 hours ago, Grumpy Bear said:
:lurk:
I've got enough forum experience elsewhere to know what this means.... Though this implies that there is a group in the pro-MagneRide camp..?
Though really the root of my question relates to whether there examples of MagneRide suspension lasting >50-60k.  I realize its expensive to replace and honestly if/when I replace I'd switch to Fox or something simple.
Not here to debate ride merits.  Not here to debate whether its expensive or not.  Just here to learn if there is a chance I'll hit 100k before needing anything or if by purchasing it with 60k already, I'm facing an immediate suspension bill.
Thanks all!
I intentionally looked fora Yukon XL without mag-ride.  I didn’t even ask anyone.  Didn’t even test drive one. I went to standard suspension.  Good luck
I'm not that dark. It means that I don't know but am as interested in the answer as you are. At least that's what it means today. 😉  Welcome to the group!
Thanks all!
We've replaced them in the 30k mi range, 40, 50, etc.  Leaking badly and or the shock fails and stiffens the ride straight up.
2019+ trucks do not have Magneride.
Well there goes this thread.
op why are you saying that it has it?
Our 2016 Suburban has a harsh ride if you ask me.  We already had to replace our left front shock due to leaking at 75k miles.  At least our extended warranty covered it.  Which with that repair and the AC condensor, those paid for the extended warranty.
Edited by Black02Silverado
Not Magnetic Ride Control
Adaptive Ride Control (GM RPO code Z45) is not just another name for GM’s incredible Magnetic Ride Control, since ARC does not use magnetic dampers/magneto-rheological fluid. Instead, it uses different (and perhaps less sophisticated) active dampers.
Magneride is rpo Z95
Edited by elcamino
In full disclosure, I'm looking at a 2020 Yukon XL.  I posted in this forum as it appears to be much more active than the Yukon / Suburban forum and I was hoping to get a handful of responses from owners with 2013-2016ish trucks who might give me a sprinkle of hope that this suspension isn't just expensive trash.
I hated the mag ride. It was awesome in the Camaro and the cadi cts I drove that had it, but the denali I hated it.
it gives so much feedback. You can feel basically running over a quarter in the road. I want my luxo barge to be luxurious, floaty, and silent. I don’t want to know whats going on in the outside world. I want cracks in the road, potholes, and small children to give me zero feedback when I run over them.
    • I have changed oil and filter for years by starting a cold engine to warm oil up, let it run 5-10 minutes depending on temperature. Drain until it starts dripping, refill with quantity from owners manual or get it close.
    • I changed the factory fill oil in the rear diff of my truck for the first time today and the miles is close to 9000 on the truck. There was a lot of fines on the magnet, a very thick layer but working it through my fingers it all felt like mush and as most know it appears like graphite, so no surprise chunks anyway. Certainly was time to do it from my thinking and could have been done sooner but the oil didn't look awful but sure wasn't new looking and never expected it to either. I did use some solvent to help me clean out the bottom area of the axle housing, just get any other stuff settled at the bottom washed and wiped out of the housing for the bit of effort it takes. I used Amsoil Severe Gear 75W90 in the easy packs to try out what they are like and I used up 4 packs and didn't spill much at all in the process but did take all four of the packs and go to the work bench and emptied them into a measuring container and there certainly was some in them that added up to something, then poured that into one of the easy packs and squirted in what I could get out of it. I would say the level is within 1/8th of an inch of being level with the threads at the fill plug so just the perfect amount. Once again, more than what GM says the fill volume is but computes with what others are adding to their rear diffs as well.
