So with the Amazon module hooked up the way they say to. Does anyone have issues with the mirrors??? More so with a remote start.  If I remote start then I have to shut off and restart for the mirror to unfold if not the mirror attempts to unfold but won’t. Maybe I got a bad module??
I don't use remote start very often. But I just did and mirrors remain folded. The mirrors do not unfold with remote unlock or with the exterior buttons on the door handle. Once in the truck pushing the brake pedal and the start button the mirrors remain folded. Using the switch the mirrors can then be unfolded.
On 8/8/2024 at 9:00 AM, Tlee6 said:
No, that switch will not work, I attempted to make it work without success.
I bolted and wired up the mirrors last night per your diagram. Worked right away and super happy with it. One issue I had was if I play with lock/unlock while driving, the mirror actually folded and would not open again (I have not done the momentary switch yet). I want to get the two lamps going... the one that faces forward and rear next. I do have the task lamp wiring. I just need to find the pin map for this mirror and re-pin it to match the same wire that powered the task lamp on my previous stock mirror. It will be my life's mission to figure out how to get that OEM switch panel mirror fold button to work. : )
On 8/8/2024 at 3:03 PM, Tlee6 said:
The switch is the momentary switch I installed.
Will pressing the switch say to the left always unfold mirror and pressing to the right unfold or does it depend on the position they are at when pressing switch?? Only asking as I’m looking for a switch and one says in/out.
I am pretty sure I put the info on the switch I used in on of my posts. The switch had 3 connections. Center connection is for power. Connect the fold out wire from both mirrors to one side and fold in to the other side. I installed the switch in verticle orientation. When I press and hold my switch up it closes the mirrors and down opens them.
  • 4 months later...
On 2/13/2024 at 4:54 PM, Timothy Lee said:
You have to hold the switch until the mirrors are either full open or closed.
I wonder if you hook up the momentary switch to the same lock and unlock pins(piggy back them) and use a diode on the line that goes to the BCM so the 12 volt signal doesnt back feed to the locks so you dont have to hold the button down, just press and release.
When you remote start you are giving the module the ACC +12v telling it that the truck is running and not to fold/unfold during driving, GM vehicles have what’s called RAP (Retained Accessory Power) basically when you turn the truck off but the radio stays on until you open your door. I believe I used that RAP source from a fuse tap and it didn’t turn on when remote started, it only turned on when you got in and pressed the start button. There are many configurations with these new trucks, so you have to just test different fuses until you find what you need
constant 12v
engine running vehicle not on (remote started) 12v
Accessory 12v vehicle on engine not running
accessory 12v vehicle on engine running
accessory 12v RAP runs for 15min or until drivers door is opened after engine is turned off
  • 7 months later...
What are the terminals being used to add to the OEM door harness for the mirror? I ordered the ones originally mentioned but they are too large for the connector and I cant for the life of me find the right ones. Reallty wanting to wire up powerfold for my tow mirrors.
Edited by JonMS
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
