I have 2012 Silverado 1500 Lt front differential when bad, I bought a used one but it was 3.7 and mine is 3.4 my question is can I change the gear ratio in the 3.7 to 3.4  I change the ring gear and the pinion thank you
Might be less expensive to change your rear gears to 3.73s, your truck will certainly like it!
That is also a great idea.  It will wake it up some for sure.
6 hours ago, CamGTP said:
He'd have to tune for the gear change, so it becomes less cheap.
You're right!  And so worth it when done right!
how much will cost for the tune for the gear change
Thank you for your advise it is something to think about it, But I do not know to reset the computer to gear change any suggestion will be appreciated. thank you.
you would need to take it to a shop or dealer to get that done.  It all depends on how much time is involved for them on what it would cost.  A shop might give you an idea, as to how much.  A dealer should have a book for how long it will take, and charge roughly according to that suggestion.
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
