Is there really any difference in driving in 2WD versus Auto as long as I’m driving on dry pavement?  I’ve always driven in Auto mode, but to be honest, I don’t really understand what it does.  I understand the other modes.  Reason I’m asking about Auto, beyond just understanding it, is that I’m wondering if I’ll get better gas mileage in 2WD versus Auto - again, on dry pavement.  Thanks.
Quick reply from someone who has a very limited understanding:
Auto runs RWD but activates front if senses slip. There is always "some" engagement with the front which will potentially lead to premature wear (and less gas mileage?).
In general, no need for Auto in the conditions you describe. Use 2wd for dry pavement, Auto for Rain/Snow type conditions on pavement. You said know about 4wd hi/lo.
Edited by ChriZ71
  • Thanks 1
In GM's wording:
AUTO (Automatic Four-Wheel Drive)
Use when road surface conditions are variable. When driving in AUTO, the front
axle is engaged, and the vehicle's power is sent to the front and rear wheels
automatically based on driving conditions.
This setting provides slightly lower fuel economy than 2 m.
  • Thanks 1
Auto has the same affect as driving with the hubs locked .It readies the truck to be placed in 4wd instantly.
Drag created uses more fuel and wear/tear on front driveline. Some lift kits recommend not using auto mode with their kits installed.
  • Thanks 1
From GM's website:
If road conditions frequently alternate between high- and low-traction areas, consider using the “AUTO” setting found on select GMC electronic transfer cases. This setting allows your GMC to automatically distribute torque to the front axle by anticipating the need for additional traction.  Shifting into “auto” engages the front axle, but the transfer case sends power primarily to the rear wheels in normal conditions and the clutches modulate torque forward to provide stability and enhance traction to the vehicle.  Although not always optimal for efficiency and wear of your vehicle 4wd driveline, AUTOMATIC 4 HI can be used on any road condition without risk of damaging your vehicle.
While 4WD Auto is engaged, the front differential is engaged, albeit in small amounts when grip is adequate, and therefore additional wear is occurring to the system.  In layman's terms, 4WD Auto is 95% RWD and 5% FWD until the clutches in the transfer case sense slippage, at which time they tighten down and transfer more power to the front wheels.  If there is no indication of adverse weather or dangerous roadway conditions, there is no reason to be in 4WD Auto as you are only adding wear and tear to your vehicle's 4WD system.
Edited by Gangly
  • Thanks 1
I put it in 2WD today and it did feel a bit lighter for steering.  Hard to explain, but it does seem different.  I’ll leave it there until winter.
Most anytime you switch from 2wd to 4wd, or vice verse, on concrete you can usually tell a difference in the steering.  That felt difference is the force generated from a drive axle trying to steer vs a neutral/rolling axle trying to steer.
Take a look at this, it does not use the verbiage AUTO 4WD, but think you will understand how it works from the video.
  • Thanks 2
  • 3 weeks later...
Zero need to run AUTO on dry roads.  Heavy rain you could if you really wanted.  AUTO is right at home in the winter so like trace to 3-4 inches of snow on the roads or slushy muck.  If the snow is deep, unplowed 6 inches+ 4HI.
GM's AUTO position:
- Front axle engages.  The truck activates the front axle actuator to engage the front axle so it can put power to the ground.
- Transfer case.  Inside the AutoTrac transfer cases, there is a clutch pack.  This pack when placed in AUTO regulates the power flow to the front axle.  Power flow is the same as in 4HI.  When there is zero slip detected, the truck sends 95% of its power to the rear wheels, and 5% to the front.  This 5% allows the front axle to turn with no binding/crow hop.
- When slip is detected in AUTO, the clutch pack in the transfer case will start to engage and send more power to the front axle, up to 50% of available power.  The transfer case actuator varies its position to increase or decrease the torque through the clutches.
GM's description and operation:
During the Auto 4WD mode, the power flow is the same as it is in the 4HI mode. Except, during the Auto 4WD mode, the 2/4 wheel drive actuator assembly (13) rotates the control actuator shaft to the correct torque level positions. Rotating the control actuator shaft to the various positions changes the clutch torque level. When a difference of front wheel speed to rear wheel speed is recognized, the transfer case control module commands for more, or less clutch torque.
Front Axle Operation:
When the driver engages the 4WD system, the Transfer Case Control Module sends a signal to the electric motor actuator to energize and extend the plunger inside. The extended plunger moves the clutch fork and drive axle clutch sleeve across the intermediate axle shaft and the wheel drive shaft and locks the two shafts together. The locking of the two shafts allows the axle to operate in the same manner as a semi-floating rear axle. A propeller shaft connects the transfer case to the front axle.
So 4HI everything is engaged in the case.  Actuator shifts to 4HI and applies the clutch to full on and the front axle engages.  In AUTO, the front axle locks, transfer case goes to a form of 4HI which allows for control of power flow in the case to the front axle.
Edited by newdude
I agree with your first sentence, but disagree with your second one.  AUTO is great any time the roads are slick - light rain, heavy rain, snow, ice, gravel, etc.  Usually the roads are slicker with light rain as all of the slime and oils have not yet washed away.  And people usually try to drive "normal" when it's only a light rain, and more traction is needed when driving quicker on wet roads.  In heavy rains people usually slow down due to poor visibility and ponding issues, so I find AUTO less needed (but I still use it).
I usually use the pulling into traffic example when trying to determine if you need AUTO.  If you need to turn right onto a busy street and then quickly accelerate, do you think you'll lose traction when driving normally?  If so, then use AUTO.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
    • Just wanted to get a idea of how many of you still have problems with your radio cutting out during the first few minutes of driving, my 2024 GMC Sierra still does this after a little over 2 years of complaining to my dealer about it, and OTA updates no longer complete, the check for updates in settings is greyed out for the second time while trying to install a update, my dealer took about a week to play around with it the first time this happened, and somehow got the check for updates to work, even though it would always show system is up to date when I knew it wasn't, now again 1 month later its greyed out again when the OTA update N25-F163BU tried to install, which ironically is the update to help with reliability of future updates.
    • Prices on the hi-way are falling daily, $3.66- $3.71, Local has yet to drop, actually some are still going up, $3.87 and up
    • I finally got it to start. It was a mix of a few issues. The frame ground was in bad shape so I ran a new one and cleaned up the area to get a good connection then covered it in rust reformer then bed liner to keep it as clean as possible. The other ground I found that looked suspect was on the frame toward the back of the truck near the bed. I did the same. After pulling the fuse box out from the engine bay I found a couple of wires that looked like at some point mice may have got ahold of it. That was an easy fix. After that i was able to get control power and was able to trace down a few more connections going to the other fuse panels in the cab. After that it finally started up and runs. It sounds like an angry school bus which I can work with. No OBD2 codes, but I think since its set for a long time I should pull the turbo and get it rebuilt or swapped out, but for now im good to go. Thanks for all the advice. It got me on the right track.
