It's only $1,400 for the computer swap, credits and the tuning device through HP Tuners. It also does require the use of a dealer tool to do a VATS reset too, which would cost more money.
For that money and voiding your warranty, it's not worth it right now.
Don’t think it would be no 4K buy a used ecm from ebay if your 2019+ it’s a e90 on the 5.3 & 6.2 and send it to hptuners
what camgtp said above it’s a lot of $ but in my opinion $ well spent I like access to my stuff lol. One thing I forgot is I already own hptuners pro so it would be another expense for you but camgtp broke it down for you.
Edited by bjr2020 6.2
11 hours ago, Grumpy Bear said:
That is caused by a ridiculously low idle speed. Tune it. Even 50 rpm helps.
Yep. I tuned mine to be 100 RPMs higher at startup and 50 at idle.
FlashPaq F5 tuner.
2 hours ago, Robby James said:
Isn't it not tuneable until I drop the 4k to get ecu swap?
Yea, see I missed that as you posted on the 2014-2019 forum. :uhoh:
  • Sad 1
FlashPaq F5 tuner.
Got rid of the shakes too didn't it? 😉
To be fair, I never had that, I just wanted to have the idle a bit up as it did make a difference on starting off HP feel
at 35 percent i am usually around 5k miles depending on how much towing i do. sometimes it is around 4.5 k. how does raising the idle effect the tranny when you shift from park to drive
It really doesn't change anything. I notice no change and I have mine at 700rpm in park for faster winter warm up's
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
