Checking the logged code(s) would be your next step.
That would be the easiest fix.
Probably a good idea to buy a new set of OEM plugs being that you are at nearly 100,000 miles.
Pull the plugs, inspect them, inspect the wires and see if you find any specific problems.
3 hours ago, Teodoro Rinconeno said:
Code detected PO300 Random/
Multiple Cylinder Misfire. Will replacing spark plugs solve the issue .
My daughter's '14 Cruze did the same thing at 135K miles.  Replacing the spark plugs fixed it, especially since one of them was cracked in two places, was shorting out to the block.
Replace the plugs with OEM is where I would start.
Edited by diyer2
Yes, stick with the OE plugs.  It is well known on here that the original plugs perform the best.  Keep us posted.
