Well I'm old school and checking oil on any motor is standard operating procedure in my book. So your logic makes no sense to me. Buy hey you roll the way you want.
  • Thanks 2
51 minutes ago, johnnyquick said:
obviously you should not need to unless you saw a leak on a newer vehicle like this.
I expect some smart comment but this is not 1978 and this truck should not be using this much oil, THAT is why NHTSB is investigating GM.
HOWEVER I will say that once you realize GM makes crappy A**ed engines that use oil like a 1947 Packard then you should start checking it..lol
Mine WAS drinking oil like crazy until I did a flush and switched my grade to 10-30 as opposed to 0-20w and use only HIGHER quality oil than the idiots at the dealer put in.
Buying another brand next time unless we get the Escalade V with the handbuilt ZR-1 engine.
Cheers
Who runs 0w20 in this truck? Yikes. It’s spec’ed for 5w30
  • Haha 1
I will say I am confused by that statement as well but that got me wondering as per Lundimpacts potential oil consumption issue. More facts need to be known to really nail down if the engine is in fact using oil. There are various scenarios that could have hidden the issue until now or if the issue just happened recently to cause excess use of oil ( again if in fact its actually using oil )
Facts like were the prior oil changes since the vehicle was bought used, monitored for level right from the point the oil was changed and let sit for hours on a level surface ( preferably the same spot each time the oil was checked ) before checking and that the engine oil was at the full mark right after the oil change service was done. And then tracked along the way in periodic checks of the level.
Was it for certain that the correct oil viscosity was put into the engine on this last oil change and again was it confirmed to be full at the start of this last fresh oil change. A thinner viscosity oil accidentally used could make that difference or perhaps even a different brand of oil. Also who is to say it was at the full mark at the beginning of this oil change if it was not checked to confirm a shops work if it was a shop that performed the service.
Also going back to a prior oil change, its always possible it was over filled or driven differently at that time and it used less oil or had more oil in it to begin with and why it never triggered the low oil level warning.
In typing this out and thinking about it, its no wonder I prefer to do my own oil changes on equipment as then I know for sure what oil went into it and at what level it was at that point, and then checking it regularly on the same or level spot to know all the way through to the point of needing to do the next oil change, as to how much oil the engine is consuming. But basically my comments go back to the basics of what diyer2 said, making it a standard practice to check the oil level regularly rather than depending on a shop or make assumptions the oil level "should" not drop. Of course GM came out with the cover their butt statement about how this engine in their mind is acceptable to use a quart of oil every 1000 miles/ per 100 gallons of fuel as I imagine has been said a few times in this thread or the forum. Also a shop is not even going to know the oil level is dropping unless the vehicle owner says something as shops just drop the oil if that is what its coming in for and they have no idea where the level was before they did the oil change because the shop is only concerned about getting the service done as fast as possible. Of course it would be different only if a vehicle was on warranty and its a dealership going through the motions of changing the oil and keeping track of how much its consuming.
Edited by Chuck FB
Yup I'm still here, watching and waiting. I keep meticulous records of maintenance and gas mileage and ONLY have oil consumption when towing. My travel trailer is not heavy but does catch the wind like a sail and makes this engine work. Still, even under a heavy load I didn't expect this but not much I can do at this point. Currently at 59,453 miles and no other major issues. Just towed my camper over the weekend at was getting 4mpg at 71MPH driving into the wind. Really sucks 😞
I am curious as to what typical miles you put on an oil change interval as well as the brand ( and named type of oil and viscosity within the brand ) you are currently using. Put another way, if you have shortened the oil change distance and tried other brands of oil to see if they respond similarly with the oil use pattern ?.
Also have you noticed if the oil use ramps up higher for a given distance in the second half of the miles accumulated within the oil change period. I know myself with various engines over the years in vehicles or equipment, the oil level would often maintain well for the first number of miles or hours in a sound engine and then it started to ramp up in usage and use a marked increase in oil in the later part of the time/distance the oil was in use. Basically like the oil and additive package was being used up and with that I speculated some oil sheering as well.
FWIW
My truck started burning oil at about a yr old, 25-30,000 mi. And yes it was about what the ridiculous GM spec says, 1 quart / 1000 mi.
Was always using cheap oil and filter. After reading you guys argue oil and then talking to my mechanic friend, started on M1 oil and filter, and reduced down to 4000 interval. Never burned oil again. 65,000 mi now.
  • Like 4
I have been running GM D1G3 labeled full syn since new and at 10,000 miles just got back from a 4000 mile trip with about 60% of those miles pulling a 5tth wheel and hauling 13000#
I added about 8 ounces to top it off while arguably towards the top of the full mark.
Yes, my fault on lack of detail. 99k Saturday morning on the odo when message flashed.
I change my own oil and keep detailed records. Last change was 7.5 qts out, 8 qts in. Kirkland 5w-30 full synthetic, Delco pf63 filter. No leaks anywhere.
Was cold here and I probably spent more time idling in the last 2 months than I normally do, however nothing excessive or abnormal for a truck that is intended for use in a fleet/ work application. In January I towed 2 snowmobiles 500 miles round trip, which is something we could do with a car so not overworking the thing by any means.
Taking a road trip from western wi to Fargo in a few weeks, going to change oil immediately before and monitor. Same at the end of April driving to Chicago (maybe it'll get stolen there and spare me the pain of more troubleshooting lol)
I have always used Mobile 1 full synthetic and a mobile 1 filter. here is a screen shot of my maintenance log and fuel log for reference.
How often do you service the oiled air filter?  You show not ever servicing it. If its not oiled but changed or cleaned how often serviced?
That is excellent information and as I see customboss was also wondering about the servicing of the k&n filter, I used to run one in a truck of a dated vintage that had no air flow MAP or MAF sensor and still own the truck and I did service the filter regularly. However for a few reasons I came to the conclusion that it was probably in the "new" engines best interest not to run one and go back to the dry filter element and I took that nice pricey k&n and threw it in the garbage. Having said that I don't mean to shock you by that comment but I have my own reservations about the filter and I certainly won't be putting one into my new truck.
Ok so my own personal thoughts ( and no I am not a mechanic ), I'll put it this way with your truck with my line of thinking and lets hypothetically say that you sold me your truck and you had told me its history. Knowing that direct injection engines seem to be even more prone to fuel dilution issues, I would start out by using the same brand oil but change it at 3000 mile intervals and grab a sample of oil at that time to send off to see what the fuel dilution number looks like as well as whatever else it might tell me like sheered viscosity ( or if fuel dilution lowered it ) and so on. I would take the k&n and set that aside and put the factory dry filter in but also get at the MAF sensor and clean or replace it and clean out the filter oil if any within the intake tract ( although probably the factory box would go back in to fit a factory filter ). I would run some techron fuel injector cleaner through it at intervals to help clean the injectors to give the best spray pattern they are able to produce.
As to the last point. lol. But criminals don’t like trucks that burn oil so you are probably good haha.
    250.6k
    Aries68
    Aries68
  • Who's Online   5 Members, 0 Anonymous, 364 Guests (See full list)
