Looking at a 2021 AT4 1500, loaded tech package and all, not the Carbon pro but does have the 3.0L. Kicker is it has 34k miles. What would you offer for the truck? It’s hard to gauge the price of trucks these days.
What do you feel comfortable offering?
You are in no way obligated to buy if you if you make an offer. What are other similar (not exact) going for in your zip code?
Try Cars.com, Autotrader, and any other internet source you can find. Might help you make your decision.
Do you know the accident and repair history? If not, get it and then decide if you want to buy the truck. I would check KBB and deduct 2 year's depreciation (about $10k) and then add 10% to that amount for a market adjustment.
34,000 miles on a '21.
Hasn't been sitting still much!
Somebody updated to stay under the bumper to bumper. (yes, diesel powertrain is 5yr/100)
If you are going to put the typical 12,000 per year on it, it will always be a 'high mileage' truck.
Value it accordingly.
10 hours ago, skully85 said:
Carfax is clean. Tax, tag and fee would get me at $58 OTD. My only concern is the mileage on the 3.0L but it’s not a deal breaker.
You can get a brand new AT4 with no options for about that much, keep that in mind. I’m not sure what your area is like but dealers around here have trucks rolling in regularly. Talk to them and see what they are getting that isn’t already sold.
If you have to have the options, and this truck has everything you want. I wouldn’t be scared of the mileage on the 3.0. With that said there aren’t many out there that have gone real far just due to it being new. so, there isn’t a lot of long term data from the public, I doubt any issues are to be expected.
Only you can decide if that price is worth the truck. I don’t believe the price is out of place in this current market.
There is a private party2021 GMC sierra at4 for$58,000 and it has not sold in well over a month.  2021 GMC Sierra AT4 1/2 ton diesel - Heads up display, technology package - Split tailgate - Tonneu cover, spray in bed liner, spacer.png
Seems like a total waste of money to me. You lose what..... $500... $1,000 every month just in depreciation alone?
A new truck that 2 million other people already own. And no one will be impressed. No heads will turn.
If I was ever going tyo drop $50K in cash on a rig, it would not be a brand new... Chevy truck? Haha. No way.
How about buy two or three of these instead, for less money:
47776344d1395037414-f-s-1970-blown-corve
  • Haha 1
  • Confused 1
Hey, come out to the parking lot and check out my new:
DODGE VIPER !!!
Oh, I mean... this brand new truck that I bought. Ya, I know there are already 4 brand new trucks in the in the parking lot, but that one over there is mine. No, the one next to that.... The silver one....  The silver one on the left.........
Oh just forget it, lets go check out my co-workers DODGE VIPER !!!!
Edited by Supreme Pizza
  • Haha 1
  • Confused 1
A quick check online my local area truck prices like the one here are in that range new.
Really? With the internet real easy to check prices on anything. YMMV
This is why you buy a truck?
:uhoh:
About the last 6 years of my working life I didn’t run the roads as much. Just back and forth to my office 9 miles. I bought a 92 stroke blown 92 Chevy truck for work duties. Along with 64 elcamino, 98 two door Tahoe, 64 retro GMC and my mid life crisis Genesis coup sports car. The only one I kept was the 92. The sports car got traded for a new truck just shy of retirement. I didn’t have them all at once. With the exception of the retirement truck never more than 20 grand invested. All returned a little profit. Especially the elcamino.
    • Anyone have any info about backorder time? It's classic 4th of July hot here in ohio.
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
