I currently own a 2021 Trail Boss wit a 6.2. I know this is a subjective discussion but looking for opinions on best cold air intake. I had the K&N on my 2011 Silverado with the 5.3. Just looking for other opinions.
S & B is what my last 2 have been..very pleased with their products. They don't make ridiculous/"bogus" HP/TQ claims. They just state their systems have the best air flow
Many have the Roto-Fab..heard many good things about them. They probably look the best inside the engine bay.
Others are Cold Air Inductions, Volant, K/N
I personally just use the Air Raid MIT with a drop in filter and stock box.
Airaid has a diy kit; mount a hood scoop, straight off the throttle body. Short of that I would say keep the stock one. Short of that I personally would go for the rotofab or afe.
GM Performance.  It's a bit more expensive, but it gets the ECU reflashed, carries a GM warranty, and is California CARB compliant.
You can't get the GM Performance intake on a 2021 unless it was optioned for one from the get-go.
Stupid GM.  Why do they have to ruin the good things?  We, the customers, are quite capable of doing that ourselves.
On 1/4/2022 at 4:11 PM, Springsfd158 said:
Which unit in your opinion is the best mix of value & performance?
I'd say OEM unless you intend to drag race your truck.  Then I'd go with the GM Performance CAI.  CAI is mostly just a noise box unless you spend a lot of time at WOT.
  • Thanks 1
Doesnt the new body style have a different intake style than the previous? I know on my Sierra it looks like it comes from the top above the radiator and if memory serves on the 16 Silverado it came from the fender. If thats the case, wouldnt that change the test results from BB? Still good info but wouldnt it be different?
The black bear cold air induction testing was done on the K2 trucks and does prove that CAI work!  I’ve said this as well. You will always have “certain people” who will argue till their black and blue with you, but they are a very reliable performance shop. I found the data very interesting. I wish S&B would have had a unit available for them ti test. They make great products.
The main difference from my 2018 (K2) Sierra was the CAI system was on the passenger side.  My 2019 (T1) High Country the CAI is on the drivers side. And yes their is extra air coming in from the frontal grill area ductwork to the fender area and CAI assembly.
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
