Hello, Currently my weather is -30. Normally to warm up a battery to help the engine, I can turn my ignition on to the start option and have the battery warm up to around 10-15 seconds then start my precious vehicle.
i have a 2019 silverado keyless ignition. How can I do the same or is this longer an option as I haven't found any area to do the same with my key in my key fob.
Any suggestions would be greatly appreciated.
thank you
thank you
Push and hold button, without stepping on brake pedal. The whole dash gauge panel will come to life, once held long enough.
Maybe you're thinking of glow plugs on diesel equipment? Doing anything like that prior to starting your truck is just wasting energy that could have been used for the cold start. If you want to warm up your battery take it inside the house and re-install when your ready to go.
Edited by M1ck3y
21 minutes ago, diyer2 said:
What? Really? Troll?
What?
Why would you say that? My response was genuinely intended to help answer the op's question.
Edited by M1ck3y
bunnys right , when its that cold putting a slight load on the bat excites the electrons to get the current flowing before hitting it with the big amp draw from the starter
I agree. Key cycling used to be a thing before vehicles were controlled by computers and battery technology was in its infancy. You won't anything in the owners manual about key cycling if the vehicle fails to start.
Edited by M1ck3y
OK
Never heard of such a thing. It either starts or it don't.
maybe not the batteries though. when its that cold if it doesn't fire right off it stands a good chance of flooding cuz the gas won't fully vaporize. I would be using a block heater.that usually keeps it a little warmer under the hood
Help me understand how they test a vehicle without testing the battery.  The vehicle is turned off and sits at some point during the cold weather testing.
And, there's this from the owner's manual:
"If the engine does not start after five to 10 seconds, especially in very cold weather (below −18 °C or 0 °F), it could be flooded with too much gasoline. Try pushing the accelerator pedal all the way to the floor and holding it there while holding the key in START or ENGINE START/STOP for up to a maximum of 15 seconds. Wait at least 15 seconds between each try, to allow the cranking motor to cool down. When the engine starts, let go of the key or button and accelerator. If the vehicle starts briefly but then stops again, do the same thing. This clears the extra gasoline from the engine. Do not race the engine immediately after starting it. Operate the engine and transmission gently until the oil warms up and lubricates all moving parts."
Edited by Transient
i don't know if you have ever dealt with vehicles in subzero temps but most of the time that doesn't work. you either get it inside to warm it up or you change the plugs and hope it doesn' t flood again when you try to start it. holding it to the floor is supposed to stop fuel flow but the plugs are soaked by then and its hard to get it to start even without gas cuz whats there won't vaporize. so the idea behind putting a draw on the battery is to wake it up and get the electrons flowing to get max amperage when you hit the starter. I don't care where they test it when it's that cold its gonna crank slow even with 2 batteries.
Grew up in Northern Utah.  Below 0°F is not unheard of there.  Spent a couple years living north of Chicago.  -19°F with a wind chill of -40°F is the coldest I can remember experiencing there.  My wife got the garage while I parked outside due to her taking the kids to daycare.  I don't recall ever having an issue with my vehicle starting in the cold.  I've been driving GMs exclusively for over 20 years.
As for GM's cold weather proving grounds, here's some info:  https://gmauthority.com/blog/gm/gm-facilities/gm-canada-facilities/gm-cold-weather-development-center-kapuskasing-ontario-canada/
Edited by Transient
@dabunny
Ignore the haters.
Most every manufacturer is using the wide open throttle (WOT) while cranking thing for clearing floods.
If neither brake or throttle are pressed -- and button held for 10 seconds -- idt will go into an 'accessory mode' which is sometimes desired for troubeshooting without the engine running.
And while were at it, when starting, with foot on brake, it is not necessary to hold the button to start -- only a quick 'press and release' is necessary. n
Button (with foot on brake) does the same thing as using the fob.
Either one sends a 'request to start' signal to the BCM.
ECM and BCM to whatever checks they do, and when they decide everything is good - (including finishing  the glow plugs on the diesels if necessary) -- they send the crank command.
Releasing the button (or key in vehicles so equipped) does not cancel the request.
Been 'bump' starting our GMs for many many years.
Edited by redwngr
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
    • Fix one problem and find another.   Truck didn't have a thermostat in it so I flushed out the system today and refilled with 50/50 Dexcool. This truck is so old (LOL) that it has a sticker under the hood alerting people to the fact that it contains such. There is also an orange supplement with the owner's manual alerting the owner that "Your vehicle is one of a number of late production 1995 General Motors vehicles that use a newly developed engine coolant in the cooling system..."   I was still a little flummoxed by what seemed like a rich condition (exhaust smell, and a puff of carbon with a punchy rev). While watching the coolant temperature and testing the thermostat with my scanner, I happened to notice the IAT (incoming air temperature) to the intake was -40F. I know the temp is below average today, but I can still feel my face, and I was wearing shorts.   D'oh!! I realized I had never plugged the IAT back in, and the airbox was out while I was doing coolant. So I paused, reinstalled the airbox and plugged in the IAT, and viola. Things cleared right up, and I watched the coolant temp climb to a reported 198 degrees on the scanner (195 thermostat) and then it dropped to 194 (open) and then back up to 198 and held. Let it cool, came back, checked the coolant level and was satisifed.   Victory lap?   It needed more than the couple of gallons of gas I put in it from almost bone dry, so I ran it up to the gas station. It had earned it, or, at least I was pretty certain I wouldn't be draining or removing the tank anytime soon.   CEL popped on just as I was cruising a nice steady 40mph, just after coasting down a slight downhill curve.. Of course, it did, because, why let me enjoy not having dash emojis for a little while.   I just happened to have the scanner plugged in. I don't text and drive but I might scan and drive. Don't tell the police.   P0401, EGR flow insufficient.    Well, hello, EGR... ...my old friend! Welcome to the party, now that the engine reaches the factory-programmed operating temperature. I'm sure it was gagging on hostile, rich exhaust and carbon this whole time so I'll take it off and look again.   At least it's easily accessible, and worst case, about $65 to replace.   To keep, or to sell... Hmm. I want it running correctly either way. It's easier to sell when there are no fault codes.   It needs tires (they're aged out and cracking)   It could probably use an oil pan seal, or maybe the timing cover gasket/ junction with the pan needs redone because I've got an issue there that leaves a drop of oil on the floor.   If I do tires I'm sure they'll say the ball joints could use freshening, and, and, and, and.... At some point I'll have to stop. I can't (shouldn't) make it perfect, that's not what this rig is.
    • Take it back. That's about all you can do.  Mark
