Just tried again after an hour charge. Same problem. Also said service steering column lock. Left a message with my dealer service. Did a remote lock but headlights are not going off. I will give it a few minutes.
What a mess. I had to manually shut off the lights. Got all kinds of messages, service steering, battery save mode, battery low, steering column, lower window, etc.. SCREAMING!!
Does your truck actually HAVE a steering column lock? My '24 does not, and I got that message on mine at one point. They ended up having to re-flash the Gateway Communication Module because a bad OTA update sent me software that wasn't actually for my truck (and this is all-too-common).
Great point. In my frustration I didn't even think about it. Finally laughing.
The truck is with the dealership. I am expecting at least a month. I gave the techs permission to drive it anywhere they need to finally find a solution. We will see how it goes. Hopefully GMC will step up and help them figure this out. There are enough of us who have verbalized the problem, not to mention those who have not, that it should be a priority for GMC.
Got mine back after months in the shop, again. So far, so good. Its usually about the time I start loving the truck again that it acts up. I had a heart attack a couple of weeks ago and I'm hoping things are fixed with the truck, finally. But if it does it again, the problem will probably take care of itself because that should give me the big one! lol
Well, after months and months of downtime, the latest try (which was pulling a pin in the drivers door) seems to be the solution. I have tested it now for over a month and I have had no problems. The only glitch I have found is with my Kicker Speaker system in the tailgate (not very loud anymore) but that could be completely unrelated. Keeping my fingers crossed with the colder weather coming in I will use the remote start more often. But it seems fixed. Not having it several times for months on end kind of soured me on the vehicle but here's to hoping I can get some good use out of it now after a couple of years of this.
  • 6 months later...
What pin was pulled?  Sent PM
I don't know. Your tech can contact Fremont Motors GMC/Chevy in Riverton, Wyoming.
So far so good for me after I fixed my leaky back glass.  Evidently water was leaking on to electrical connections back behind the rear seats.  The dealership was clueless.
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
