Just picked this up last week, traded my 2019 in. Trail Boss Midnight edition, 6.2L, Performance exhaust, which sounds amazing. I have a few things coming this week to put on it.
Edited by Mcandrew67
  • Like 6
Here is mine.
LT Trail Boss
3.0 Duramax
  • Like 8
My loaded except sunroof Elevation came in yesterday. Ordered March 17, Built week of April 18. 3.0 liter Duramax with towing package. Dealer still needs to install assist steps. Definitely need to match front window tint with rear. I pick it up tomorrow.
Edited by dickpencil
Nice!  Looks like it has the 6ft 6 inch bed. I love mine on my High Country. Don’t see many of them around.
Edited by TNTSilverado
On 5/17/2022 at 7:15 PM, Clynwoodg said:
Here is mine.
LT Trail Boss
3.0 Duramax
On 5/19/2022 at 8:46 PM, quiksilver81 said:
Just picked up our RST yesterday evening. Tint and some debadging will hopefully be done this weekend and detail and ceramic coating the next.
Without a doubt, the two best colors GM added to the lineup on Silverado.  Sweet trucks!
Here is mine - 2022 Silverado 1500 Crew LT 4WD with the 5.3L V8.  We picked it up just over a week ago.  Replacement for a 99 Silverado 1500 with 32,000 miles which was stolen.
On 4/6/2022 at 6:32 AM, f8l vnm said:
That gauge cluster is now tops in the game if you ask me. For years GM had the most boring set up but now i absolutely love the way this digital cluster looks and the layout.
they killed it with the new model.......brilliant layout, just sucks on timing.......dealers local still asking 5-10k over MSRP......but GM did a great job, sucks peeps have to wait for retrofits while paying top dollar
On 5/12/2022 at 8:43 AM, BigBadSierra said:
279607999_1062244614705224_6750369166051226910_n.thumb.jpg.dc17c11c58f29c902951b2607ca52243.jpg279232219_703427117550483_6286136033555461442_n.thumb.jpg.cb5c93412956318e69a9ed6c60aea4e4.jpg
cayenne is by far the best color GM has.......miss my 21 elevation, by far the nicest looling truck ive ever owned.....i was in shock everytime i walked up to it......
Nice truck. I’ve got a similar build on order. Can you share some more photos when you get a chance? And what’s your payload number?
Do you guys think the back end will have more rake with the max tow package? Kinda looks like it from this photo.
Here's a couple of pics. I'll post better ones when the front tint gets done. The max trailering with a 4x4 is 13000 pounds.
I’ve been kicking myself for ordering my AT4 in black instead of Cayenne. Cayenne was my first choice but I went with the safer color at the last minute when taking with my dealer. I know I’ll like the black once I see it and get past it but every time I see someone pick up a Cayenne version I can’t help but think how much better it looks.
17 hours ago, dickpencil said:
Thanks for sharing.  Can you tell us the GWVR? thanks
Yeah thanks for sharing @dickpencil. Your truck looks awesome, congrats.
I was kinda hoping the payload would be in the 1800lbs range with the max tow and duramax combo. Maybe the overall weight of the truck with the diesel plays a factor in that?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
