Seen 87 for $2.59 in a small town and the bigger cities it's floating from $2.89-3.19 still.
I saw E85 for $1.98 in southern MN and paid $2.49 near my house today.
4 hours ago, OnTheReel said:
I’ve been waiting for this. First “1” I’ve seen in front of any fuel price in a LONG time.IMG_0435.thumb.jpeg.02f27fcd106d6b2cd0549ec8088ce6d3.jpeg
$2.29 here.
10 hours ago, Grumpy Bear said:
$2.29 here.
$4.21 USD for a US gallons in the french portion of the 51 first state ( Québec ) socialism is expensive ....
  • Haha 1
  • Sad 1
12 hours ago, Grumpy Bear said:
$2.29 here.
You’re in corn country like me! Should be cheaper!
I live in the land of GREED. Most are 20 to 60 cents higher. I have that one station that is at the $2.29 price and rarely varies. BP took over the last Petro Canada station in Rochelle. There is a Casey's about a hundred miles south that is very close to that price but unsteady in content percent. BP is 75% every time.
I think most price it as a performance octane and not as a clean air play.
Yeah, agreed. Mine has been pretty consistent at 75% too. I don’t check every fill but I can kinda use the A/F gauge as a proxy. If I’m in the 8s to low 9s I know I have some “high test”!
I imagine we’ll start to see the switchover to higher gasoline soon. Been pretty chilly here at night but truck still starts normally so far.
Diesel still $5
Premium gas is over $5 most places now. Fake ass refinery fire in LA caused prices to jump again.
36 hrs ago. Was wrong about the .30 cent jump, it was .40 cent. $2.79. But was right about the timing. Now it will slowly drop to $2.40ish area over the next 7-10 days. BS
Edited by txab
Saw $2.73 today at a Kwik Star and a Casey's.
I've kept a chart of price since I bought the Mitsubishi and the price is for Premium but the trend is flat although the swings are wild. :nonod: Yellow is 24 point average and the red the linear average. Dead flat.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
