On 5/12/2025 at 8:20 AM, KARNUT said:
Montgomery Krogers 2.49
Montgomery Krogers today 2.59
Just got back from town with the SXS to fill it up, $3.25 85 oct no dis.
Montgomery Krogers 2.46
$3.35 85 oct. no discount. Shell gas.
Stopped at an XOM station advertising regular 87 for $3.14 and Premium at $4.80. Move on.
Shell station regular was $3.17 for regular or 3 cents more but Premium was $4.00 or 20% cheaper.
Mobil is in love with themselves. This is pretty universal in my area and senseless. 80 cents a gallon? :mad:
Still holding @$2.45.
It'll probably jump this week, that seems to be the pattern after holidays
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 298 Guests (See full list)
