Is there a way to do a survey of 5.3 owners that just let DFM work as designed compared to those that delete DFM one way or another?
It’s been done on older cylinder deactivation models. In my case on an older vehicle at 70 mph. There wasn’t enough difference to register. Of course there’s outliers. Some doing low speed testing claim some difference. If you look one some new truck stickers or information the claim is 1 mile per gallon.
Edited by KARNUT
My 2021 Trail Boss Custom did not have DFM or Auto Start but if it did I would definitely disable it. There has been a lot of problems associated with DFM.
According to GM:
    Internal components related to AFM or DFM function will be present in engines; wiring, connectors, and fuses will be present in vehicles with RPO YK9. The ECM will not be capable of activating the cylinder deactivation technology.
    When diagnosing and repairing concerns with base engine or electrical function which may be related to AFM or DFM related hardware; utilize appropriate diagnostics within SI and replace any needed components as directed by the Electronic Parts Catalog; no changes will occur to AFM or DFM related components.
    Important: Any truck designated with RPO YK9 CANNOT be reprogrammed and changed to “Turn on” the AFM/DFM functionality.
2020 AT4 5.3 w/dfm. I always drive in L9 dfm won't engage, but I do lose 10th gear.
I'd rather have 8cyl all the time. Not sure what the mpg loss is on the highway but I'm not worried about it.
My parents have a 2021 5.3 with DFM, I've driven it many times and towed with it several times and I can barely notice the DFM working. The AFM trucks are alot more noticeable if you ask me. It's only got like 5,000 miles on the truck and it's been problem free.
I recently added the Pulsar LT.
I was getting a mild shudder in certain situations and it was concerning.  Since turning off DFM it has completely disappeared and imo the shifting is much improved.
I have the throttle sensitivity set to 3 and I love it!  It took a few days to get used to the new throttle response.  Like when you drive a car that has a sensitive brake pedal and you are used to a more mushy brake pedal.
Turning off Auto start/stop is also a great thing.  Still getting used to not having to turn it off.
This thread is about DFM, but I love the Pulsar LT and I love not having DFM on anymore.  It is very noticeable, at least to me.  I have a Borla Touring cat back exhaust with S&B cai.
2020 TrailBoss LT w/5.3 & DFM. I never notice it and haven't tried to disable it. 37K miles and running like I bought her yesterday.
Going from a 2019 Silverado with DFM to a 2022 Refresh TB W/O DFM, I definitely like not having DFM.  If you can snag one w/o DFM I recommend pulling the trigger ASAP B4 DFM is standard again.
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
    • It would be sold as a "kit", lights + auth/programming code.   You can resell the code to someone else, if they just buy the lights, either new or used, and they can then use the code to get them to work on their truck.
    • Apologies in advance, this is a long post, there's a lot to explain.   A friend had a 2010 Avalanche with a 5.3 (LMG) that blew the head gaskets (amount other problems). He gave me a donor motor out of a 2007 suburban (LC9). I got it all installed, and everything hooked up. Went to go start it, and it stumbled a bit at first and died a couple times, but after trying a few times it sounded like it was running very well. Went out to go get some coolant, and came back the next day.    Upon trying to start it, the truck will crank and fire normally and the RPMs will raise to around 1,200 or 1,500, sounding great, and then the RPMs will decrease and it will just die. Repeat that a dozen or two dozen times, and eventually it will fire and idle beautifully. As soon as you touch the throttle, it will start misfiring and sound like absolute trash. When you let off the throttle it will come down and hunt around shaking and misfiring like crazy. A message will come up on the dash saying reduced engine power.    It is throwing codes for a map sensor circuit voltage High, as well as MAF sensor low frequency. With key on engine off, the map sensor reads about 4.8 volts on the vout pin, which the PCM interprets as about 17.8 PSI, contrasted to the barometer which my scan tool tells me reads about 13.5 PSI. However, once the engine starts and is idling this reading drops to about 5-6 PSI at a stable idle, and varies significantly when the engine is misfiring/ hunting like I said before. I should note that I used the intake and MAP sensor from the LC9 engine. I changed the connector on the 2010 harness to The 2007 connector. The pinouts for the sensors were printed right on the top, and I triple-checked that I put the correct wire into the correct place.   On the other hand, the MAF sensor reads consistently 0.0 g/s regardless of State. I have pulled my hair out trying to figure out this last detail. I have tried three different sensors, (all of which should be good, one of which was new), I have verified all the wiring from the sensor going back to the PCM, and have verified that the readings at the PCM are the same readings as at the sensor itself. The intake air temperature sensor is also functioning as normal. I verified all the voltages and grounds etc, and everything is as it should be. I don't have an oscilloscope to verify, but I probed with my multimeter (Klein mm720) on frequency Mode, and it reads that on initial cranking, the maf is producing between 3000 and 7000 HZ, and as soon as the engine fires that falls off to below, 1000, and if the engine continues to run, it will produce somewhat erratic readings between 5 and 100-200 HZ. It does increase notably when the engine is revved despite the misfirings. As I said before, I have verified all of the wires going to the PCM, and I have tried multiple known good sensors. I've tested all the pins and voltages from the sensor and verified them against the manual that they are what they should be. I tested all the wiring for both ohms and voltage drop, and everything tested fine. Like I said I tested at the sensor as well as right at the PCM, everything checked out.   The only other thing of note at least I think is the fact that the engine originally in the truck had VVT, but the engine I put in, the lc9, does not have VVT. I modified the cam sensor plug to work. I reference the wiring diagrams and double-checked that I modified the harness correctly to adapt it. There is obviously a code for the VVT solenoid, but I don't think that's the cause of my problems, and this friend will probably have the PCM sent off to tune out the codes at some point.   I'm writing this for my bed so I don't recall the exact codes, but I'll update the post tomorrow morning with the exact codes. And ideas or feedback much appreciated.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
