Fix the it or don’t?
33 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Good news, my daughter got married this week!  Bad news, while dropping off her 8FT tall seating chart, this dummy side swiped a mail box, AND, one of the groomsmen laid his belly/buttons of his dress shirt on the side of the bed resulting in a through the paint scratch from the mailbox and multiple smaller ones from the buttons.
$1174.00 to fix it.  My truck is my baby, I have PPF on the front to stop all the rock chips, don’t go through brushed car washes, etc., to give you an idea of who I am, but it IS a truck…
What would you all do?  It is a lot of money.
It's s truck. It's big and it's going to get scratched several times. Make look it as best as you can cheaply. You probably won't even think about the damage in a few months.
I am hoping you did NOT get a body shop estimate or this will show up on a carfax.........Fix it the $1100 is peanuts compared to the truck let the Groomsman kick in for his mistakes as well.
Oh hell, I had 0 idea just getting an estimate would show up!!  It’s a small local shop but I did get a write up/breakdown :(
How should I have gone about it?
If the truck is a spotless 'my baby' , as indicated then I'd get it fixed.
If it's in good shape but in well worn work clothes it would get likely get left as a battle scar.
If it is a small shop maybe it  was not computerized and or entered yet ask them on Monday and they can hopefully not put it in, any claims will show up so just cash it out.
If it is too late then just keep the dated pics and show the actual damage when you go to sell the truck eventually.
Carfax/Autocheck can devalue a vehicle quite easily.
Cheers
Cheers
This is great to know, thank you so much!  I will not be running it through insurance, sadly, due to various discounts I would lose as a result.  If I get a quote but pay cash, it would likely still show, I’m sure?  So if I’m gonna get it fixed (maybe), there’s no way around it showing up?
thanks again for the info!
It will not show up on anything unless you file it with insurance. I've never had anything to show up if I pay it myself and don't file. I would have it fixed if it were mine. I know it is a lot of money, but if you are not planning on keeping it for several years you need to fix it. I would have to have it fixed anyway myself, especially where the scratches are located.
If it were me I would get it fixed. those little scratches may come out with wax and the big scratch was it a plastic mailbox or metal box? The big one from the picture looks like a rub mark and that may come out. I would take it to a detail shop and see what they say. If the big one is a scratch your looking at rust later if you leave it.
It’s definitely a scratch (can feel it with my nail, so through the pain), and it’s slightly dented too.  With a steel bed, it will rust for sure with how much rain we get in TN.  That’s why I was contemplating Dr Colorchip to cover it up, but the dent would still be there then.
It’s a tough place to photograph well.
This was after I washed it, covered it with quick detailer for a very small amount of protection.
Get a mobile dent man to take of dent first .. then DR Colorchip. Think the beds are all allum now, but I wouldn't worry about rust either way.
I guess 2020 was still steel?  Magnet sticks to it.
That might work well, as Dr Colorchip is pretty freaking amazing.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 1,931 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
