So I have a question don’t get on me for being dumb just want other opinions.
I have a ls2 swapped rado bought the truck on a deal only problem was I couldn’t drive it for more than 20-30mins without getting trans hot on the dash and would go into limp mode but if you cut the engine off for a minute or two and cut it back on message went away for another 20-30mins but the actual trans temps never hit about 180
this is where it all starts.
anyway 1blown torque converter later and a trans rebuild my transmission guy told me the genius put a 2500 ecu in just to get the truck to fire up with a slight tune that pulled like a F****** freight train back to the point he tells me the truck thinks is has a 4l80 in it witch It doesn’t I have a 4l60 he said I needed to take it to a tuner shop asap so I don’t blow my trans or torque converter again because there’s a lot of major differences mainly being gear rations and shift points
witch I thought a tune would fix anyway but I wasn’t for sure so I got the truck tuned by Powerfab autosports and they reflashed the ecu programmed it and did a dyno tune
when I pick up the truck the dude shows me the power chart and the truck made 280hp 360tq
witch I think is way ****ing off but I am not a master mechanic I know a lot about vehicle but not enough to be firm on saying that’s bullshit
Why I needs y’all’s insight is because when the truck was ****ed up and giving trans hot display on dash the ****** was a ****** Ton faster and pulled a boat load harder the ass would squat the truck would drop a gear and scream so beautifully she would literally throw me back in my seat and keep in mind this is with 305/35/24s  now it’s just feels like I have a slightly beefed up 4.8
engine mods are air intake long tube headers full exhaust trans cooler and that’s pretty much it as far as I’m aware
does anyone know or have any insight as to what is going on and why I am making such low numbers or where the **** my power went??
and I would appreciate no assholes just need some info thanks!
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
