I have an 07 LMM Duramsx with 180k miles. Always changed the fluids when the wear life indicator shows 50%.
I habve been sending in an anual oil analysis for a few years.
Recently, I changed from Delvac to Synthetic Delvac 15w-40, with HOT SHots FR-3.
Anyway, my last test showed 250 parts per million of Potasium.
I have not added collant for almost a year.
I did a pressure test and the truck held presure for 15 min.
I did a test for exhaust gases in coolant and it was neg.
My question, is how bad is 250 PPM. I am not sure if I may have contanimated the funnel, etc or skewed the test results somehow.
I have oredered a new test kit, changed oil and put in no additives,.I will do a test every 1000 miles and pay atention to carefully keeping the test sample clean.
Any thoughts where most possible leake location. EGR cooler, water pump, head gaskets, intake gasket.
I have an appoitment in 2 weeks at my local GM shop to see if they can locate any possible location for any coolant contamination of the oil.
Any additional thoughts
Question I have, if you did a test that shows negative for fluids in the oil, then how are you asking about head gasket? My question is, when you start up truck, do you have constant steam coming out the tail pipe? You can tell difference between exhaust and steam by the smell, and the vapors it gives off.
  If you do have steam coming out for more than a minute, let's say 2 minutes straight, then I would say your head gasket is blown. If you check your oil, and you have coolant in it, then your head gasket is blown, but I would also change out your header gaskets, since your right thier if it is head gaskets. GM engines are known to blow head gaskets  between 125K and 180K depending on the driving  that has been done.
 Let us know what you find out.
I’ve had my avalanche now 3 years. The first two I added coolant not much about 1 qt every 6 months. No evidence on dip stick. The last oil change the service person said there was some sludge at the beginning of the drain. I added bars leak right after the change. No problem since. I actually drove it more this year. I’m almost at 180K. My model year has some problems with head cracks. I’m a big believer on not panicking and try easy stuff first. So far so good.
I had an LLY duramax that had blowouts in both headgaskets and still passed a test looking for hydrocarbons in the coolant. The oil also came back negative for coolant. The definitive test is if the upper radiator hose is hard after being run hard and then sitting all night. If you find that condition its full stop, always the head gaskets.
Mine would push coolant out when towing. The engine would get up to temp and heat soaked and then you could watch the bubbles in the degas tank (overflow)
[quote] HOT SHots FR-3[/quote]
^^^^^^^There's the reason.....
Using aftermarket oil additives with synthetic motor oils is not only unnecessary, it could disrupt the oil formulation and reduce performance.
Edited by elcamino
Be careful adding these addadituve until your engine. I had an 03 S10 w 4.3L and 3 previous owners b4 me. One of them added this same oil leak stuff in the engine. When the head gasket blew on it around 125K, we found that stuff allover in the heads. Like hard rubber pieces some size of a qrtr. We drained the whole engine out with gas, got as much as that gunk out as possible. Those pieces can cause some major catastrophic events in your engine.
38 minutes ago, Niners 365 said:
I’ll go with a crate long block probably GM.
This site is having problems quoting tweets. I was wanting to know from 64BAwagon the part you mentioned that your truck would blow coolant out while towing. Blowing it out where? The tail pipe or the Upper hose yo mentioned? If it is tailpipe, then that is as well a sure sign head gasket is shot.
It pushed coolant into the degas tank, the auxiliary overflow coolant tank. It would over pressure it when towing and the tank would blow coolant out the overflow. https://www.gmpartscenter.net/oem-parts/gm-radiator-surge-tank-84257137?origin=pla&gclid=CjwKCAiA5sieBhBnEiwAR9oh2uZ-v4zTszzLXaCTvR_zOoZEIPrzSRuCURm3r-Wjd8Wh8zuhhtafjBoCxQwQAvD_BwE
The crazy part is that it never pushed coolant out the tailpipe or into the crankcase (I had an oil analysis done AND tested the overflow coolant tank for hydrocarbons)  The gasket blowouts were sort of like a reed valve, it would push  cylinder pressure at certain temps and heavy loads into the coolant jacket. The sad part was that both heads had the blowout in the same place on the rearmost cylinder. Shortly after mine was built they changed the headgasket design. Too bad mine wasnt the update because that was a $4500 hit a couple of months after I retired.
It was at the dealership for a week and they couldnt verify it was headgaskets based on the symptoms.
Edited by 64BAwagon
When talking to the oil analysis people with Hot Shots Secrete. They stated that I should really start to plan to investigate after a second oil test.
They also stated that Potassium in oil normally indicates coolant in the oil. The good test was no Glycol was present. As they explained, the leak could be very minimal and possibly only sporadically.
My main concern is if anyone is familiar with a reading of about 250 parts per million of potassium, as how actually large or small a possible coolant leak could be.
I have another test result that should be received in a week or so.
I plan on taking the truck to a dealer that would have better leak down test equipment than I have, in an attempt to see if they can rule out where any coolant leak could be.
Glycol in the oil is the main culprit of causing damage to the engine. So if there is a leak, hopefully catching before any real damage is caused.
Mine was at the dealer for a week and they leak tested it for long periods and came up with nothing. This was months after it first exhibited symptoms of pushing coolant out the overflow and the hard upper radiator hose in the AM.
Hiking_Mike, it would be a safe bet that your head gasket has blown. Before you cause more damage waiting on tests, I would just replace it. Also replace your oil pan gasket too. The stuff in that dextrose coolant, will eat the oil pan gasket..
If you are getting annual oil analysis get the lab service to answer the potassium question. If they can’t get a better lab service.
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
