Has anyone found a decent pic of a 2024 promo truck (or other GMC vehicle) in Downpour Metallic (gxp) they could post?   I'd love to see one before I lock in an order.  Thanks in advance.
Thanks for finding this.  I’ve been trying to see what these new colors were going to look like.  I wanted to do Quikck Silver in a 24 but they went to Sterling Gray which I don’t really care for.  I am actually thinking of the Titanium Rush Metallic just because it’s almost three colors in one.  I’ve had so many summit white ones need to step out of the box.
I'm curious about the Redwood Met myself. I want the deeper red, the old Cherry Red Tint/Cayenne/now Volcanic red - but it's been on constraint so far as I know. Going in to place order in the morning so may learn more - My sales gal said it's a strange color. Probably like the "Greenstone Metallic" is a strange one. I don't do guinea pig very well, I gotta see it on something.
The 2024 build & price tool is now up. Downpour Metallic is much darker than the baby blue looking color on that dealer page. It's never the same as seeing a truck in person under natural light, but it's the best we have at the moment. I like the Redwood Metallic but wish they'd kept the Forest Green.
I was thinking of ordering the Downpour Metallic and was told by a dealer today that it's not available yet so they recommended titanium rush if I wanted the order built sooner rather than later
The Downpour Metallic on the configurator looks like my 2020 blue truck, which is a lot darker than the dealer site pic.  Like, not even close.
I like the titanium rush in certain lights, but you really gotta see it in person, in sunlight.  It can get pretty purple.  Which is fine, but not necessarily on top of my list.  I may just stick with black, which I always seem to come back to anyways.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
