On 9/29/2023 at 10:33 AM, Rototerrier said:
Your vehicle is charging the batteries while you are towing.
Yes it is, most people don't know that.  When we dry camp overnight at say a Walmart parking lot on our way to another campground, the battery is at a 100% when we stop and typically around 65% when we leave the next morning 10 hours later.  The battery on the camper is keeping our fridge and freezer cold.  It's giving us light, powering up our phones, powering the water pump when we take showers, that one battery is doing it's job big time.  After driving another 3 hours when we stop to stretch, I look at the power meter and we are back to 100% just from the truck and our 165 watt solar panel.  I love it!!!
Just had to cancel a vacation from Iowa to Maine because of this. The truck threw these errors and I suspected the solar causing it. disconnect it (2 hr into trip) in Illinois and all was fine for the another coupe of hrs. then in Indiana started again intermittently. decided better to cancel trip. after awhile it only disengaged when starting the truck.
Edited by Kevin Peele
broken link
On 8/27/2023 at 11:00 PM, UWSkier said:
My truck goes in on Tuesday for service.  Hoping they have the bulletin published by then so I can point the service director to that.  Also need them to figure out why any trailer I plug in says the running lights don't work, and the running lights are always on.  Will update what I hear.
Ah you have the running light problem too? I took it in to Chevy and it's supposed to be a "trailer light module" they need to order a part which they cannot get because of the strike. But I am also having the trailer brake issue as well.
This is true but, it does not charge with a high enough voltage (14.6-.8) volts to fully equalize a LiFePo4 battery(s) which is important for long battery life. You need a LiFePo4 enabled solar charge controller or a proper DC converter to get to the required voltage.
I just have a run of the mill lead acid battery.  When it dies I'll be switching to Lipo.  Our camper is already equipped with a selectable charge controller for the different battery types.
Yes.  Waiting on the two modules.  One is in.  Other is supposed to arrive tomorrow, but I doubt that...
Wait what? waiting on parts since end of Aug? good grief.
I have a 2024.  It was diagnosed as needing a new trailer light control module in addition to the updated brake control module at the dealership two weeks ago, which is when they ordered the modules.  Computer still saying the light module will arrive today.  It's scheduled to go in for service tomorrow.
Edited by UWSkier
 I am so glad I found this thread. I am on a sunny road trip with my 2024 3500  Duramax which is  is disconnecting it's trailer controller and chimming constantly as I tow my TT with 300 watts solar  & 1.000 miles to go!!!
I will try disconnecting solar and or  removing #84 fuse and try to keep my sanity! I will give an update to see if this cures the issue.
Interestingly the last trip was cloudy and I did not have this issue.
Turning off the solar will help but you still might see it briefly from time to time.  At least that was my experience before I bought a cheap diode and wired it in.
Brought the truck in for its first oil change (complementary) and told the dealer about the brake controller issue when towing our travel trailer. They've ordered a new updated brake controller. No commitment to when it will arrive sue to the strike.
New brake controller arrived today. Bringing the truck in next week for install and re-programming.
Shocked that it took only 5 days to get here.
both modules swapped out and both problems fixed!
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
