Got new tires today and Big O, they said I needed new lower ball joints and rear shocks leaking, I said no thanks.  Bought home and tested, raised truck up on frame so wheel was off ground hanging.  Took 2 foot bar and tried moving wheel up and down.  There was a very small amount of moment on one side and tiny amount of noise.  Same on other side, less moment and less noise.   No tire wear on the old tires and no steering problems on highway.  It seems to me a little movement is not an issue, I have no driving symptoms of anything wrong.
Seems to me I been told a tiny amount of movement like that is not an issue?   Will try to attach picture or links to my Youtube.
They also said rear shocks were leaking and needed replaced, they seem just fine.  Yes there is dust and dirt on bottom half of shocks from all gravel roads, so a small amount of fluid may have escaped and causes the dust to stick, but shocks have hardly any bounce, they are hard and they are overload heavy duty.
Try to add pic of my test, hard to do by myself holding camera and lifting bar.   Driver Side if you look really really close you can see small moment of lower and upper mount of lower ball joint.  https://youtube.com/shorts/Ogmbsqx7pLs?feature=share
Passenger Side here you may not even see the movement it is so small.   https://youtube.com/shorts/V_LXoY-A0QI?feature=share
I don't think I ever had a shock that didn't look a little like this (well unless it was new), they expect it to still look blue like top?   It may be leaking a bit, but still strong!
I hate tire stores that do this, should had stayed with my old standby store, but couldn't resist by 3 get 1 free.
Edited by Diverjer
Yeah, probably a 'up sell' opportunity. FYI, it's been my experience that you need to use a large channel type plyers to squeeze the ball joints to see if any movement to check foe wear. How many miles on your truck?
I just hit 60k miles on my '18 Sierra and when in for an oil change and tire rotation last week my dealership mentioned that the ball joints are showing some wear but not anything to worry about yet. Just something to keep an eye on since we will eventually need to replace. Im going to keep an eye on it and see where we are at next oil change. Or if I start hearing front end noises or wandering as Im driving I'll get it taken care of sooner.
Side note, my truck wouldnt pass the PA inspection because my low note horn wasnt working. I got that fixed, but learned that day my truck had a low and high note horn. 😉
Edited by Cupton
78,000 miles on truck.  I posted some video of my testing, best I could do with one person.  Sure there will be some wear, but I don't believe enough to replace.  Also, I have friend that if needed would do it for little of nothing.  I am just not wanting to deal with doing it myself and don't have the tool I need anymore.   Don't do as much as I use to, 76 years old and let someone else I know and trust and needs the work.
LOL.....I'm right there too!  And your shocks look fine to me. Us old guys need to stick together.
I checked the tire pressure as they said on paper work, they put in 30 pounds, should be 35.  It was really 35, just poor paper work.  Also, said torque foot pounds 140 which I think is right, but think they are more?  Can't loosen with my 4 way lug wrench, but have another in truck with long handle so I can get more pressure.  I work out at gym, can lift 145 pounds without much difficulty.  Should have stayed with my old tire guy.
Yea, my special tire wrench that I put 2 handles together to make a 243inch handle breaks them loose.    Got it off Amazon
Edited by Diverjer
Yep, 140 ft lb is correct. I bought a 12v impact lug nut remover along with 12v electric jack, just in case AAA can't get to me. I run 35 psi too on my new continentals.
Ball joints are done for when there is more than .5 mm of movement.  Tie rods are done for when there is more than 1 mm of movement, inner and outer.
If that's oil on the shocks, change them, they're cheap enough.
Well I imagine with a 20 foot handle, you will be able to break pretty much anything loose...
It's better to test ball joints when "Unloaded", while truck is lifted off the ground, on the frame, place a jack under the lower control arm and lift it up a little to "Unload" it, then check the play in the Balljoints.
Thanks, got to thinking that after awhile and tested using lower control arm.  Didn't notice anymore movement than lifting on frame, maybe a hair more?? No movement at all if trying to shake tire around.  Later when visiting with my mechanic friend he said- lift on lower control arm.     From what I told him, he said nothing to worry about.
Seems there are some configurations that you are suppose to lift from frame, I really don't know that for sure.
That one post above was suppose to be 23 inches- not 243 inch handle.
  • Sad 1
    btm
    btm
  • Who's Online   4 Members, 0 Anonymous, 1,312 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
