Has anyone added the unlock buttons on their rear doors?
I know some came with them but not sure exactly which models did.
Any insight would be great.
I know the GMC's did come with it. I would love to see someone attempt this. I don't know what all parts would be needed or if it's just the handles. I'm sure programming would be required.
I found another thread and it led me to believe that the chip shortage and lack of use dictated then cutting it out. However I’m wondering if I can get all the same parts and connect the wiring from the rear button to the front button and have it function the same. Might be easier than telling the truck it has a new button. Don’t know how sensitive it is to this though so maybe we’ll see once I can track down the parts.
I just traded in my 2020 Denali 2500HD for a 2024 model.  I'm very disappointed that the rear door lock buttons are not there on the '24.  Denali Ultimate is supposed to be the top, right?
I had them on the front and rear doors on my 21 AT4, I however do not haven them on my 22 refresh AT4. I was definitely bummed when I bought it.
I don't have them (rear) on my 24 SLT Premium Plus. Also disappointed in the implementation requiring a physical button. My 2015 Mercedes just has some sort of touch sensor on all four handles, just lightly touch it and it unlocks. My 2007 Mercedes had physical buttons, and eventually water gets in them and shorts them out.
I also am missing mounting buttons/brackets for floor mats on all but the driver side footwell. The rubber floor mats I purchased had buttons to clip into all 4 footwells, but only my driver side had receivers.
I'm guessing these are minor items that GM has cut in the last few years as inflation has gone crazy, hoping buyers won't notice.
Edited by DubVBenz
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
