  • 3 weeks later...
Today I got a new check engine light. This is the freezeframe. I noticed that the downstream O2 sensors give different voltages now. So maybe it was just " domb luck"?
I'm going to change all 4 of them and go from there.
Conditions for Setting the DTC
The correction limit for a condition causing a rich or lean air/fuel ratio has been exceeded.
Diagnostic Aids
  • The post catalyst fuel trim diagnostic is very sensitive to heated oxygen sensor (HO2S) design. A non-OE sensor or an incorrect part number may cause a DTC to set.
  • Certain aftermarket air filters may cause a DTC to set.
  • Certain aftermarket air induction systems or modifications to the air induction system may cause a DTC to set.
  • Certain aftermarket exhaust system components may cause a DTC to set.
Circuit/System Verification
  1. Ignition ON.
  2. Verify no other HO2S or fuel trim DTC is set.
    • If no other HO2S or fuel trim DTC is set
  3. Verify DTC P2096, P2097, P2098, or P2099 is not set.
    • If a DTC is set
      Refer to Circuit/System Testing.
    • If no DTC is set
  4. Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the conditions that you observed in the Freeze Frame/Failure Records data.
  5. Verify DTC P2096, P2097, P2098, or P2099 is not set.
    • If a DTC is set
    • If no DTC is set
  6. All OK.
Verify none of the conditions listed below exist:
P2096 or P2098
  • Air intake duct collapsed or restricted.
  • Air filter dirty or restricted.
  • Contamination of the mass air flow sensor with oil or other foreign material
  • Objects blocking the throttle body.
  • Excessive fuel in the crankcase. Change engine oil as necessary.
  • Rich fuel injectors. Refer to Fuel Injector Diagnosis.
  • Excessive fuel system pressure. Refer to Fuel System Diagnosis.
  • Fuel contamination. Refer to Alcohol/Contaminants-in-Fuel Diagnosis.
  • Fuel saturation of the evaporative emissions (EVAP) canister.
  • Stuck open or leaking EVAP purge valve.
  • Restricted exhaust. Refer to Symptoms - Engine Exhaust.
  • Improper operation of the crankcase ventilation system.
P2097 or P2099
  • Exhaust system leaks. Refer to Symptoms - Engine Exhaust.
  • Split, kinked or improperly connected vacuum hoses.
  • Insufficient fuel in the tank.
  • Leaks in the air induction system and air intake ducts.
  • Missing air filter element.
  • Cracked evaporative canister.
  • Evaporative pipes plugged, obstructed, or leaking.
  • Crankcase ventilation system leaking.
  • Engine vacuum leaks.
  • Low fuel system pressure. Refer to Fuel System Diagnosis.
  • Contaminated fuel. Refer to Alcohol/Contaminants-in-Fuel Diagnosis.
  • Lean fuel injectors. Refer to Fuel Injector Diagnosis.
Nothing in the diagnosis of that code indicates replacing an O2 sensor. The O2 sensor is telling you something else is wrong based on its readings.
Don't shoot the messenger.
According to my dianostic check the troublecodes are p2097 and p2099. The last time after I reset the dtc only a p2097 popped up. As you can see in the last picture of the freezeframe.
Your dianostic aid is very helpfull but the links don't work here in holland. For example, when I click on the "fuel system diagnosis" , I get a no access message on my computer. It's like the website is blocked off. Or maybe it's only for people in the US? I don’t know.
Is there perhaps a different way to check the fuel and injector system? Maybe a different link?
Thanks for the great input by the way😁.
Quote
Circuit/System Description
The engine control module (ECM) supplies voltage to the fuel pump driver control module when the ECM detects that the ignition is ON. The voltage from the ECM to the fuel pump driver control module remains active for 2 s, unless the engine is in Crank or Run. While this voltage is being received, the fuel pump driver control module closes the ground switch of the fuel tank fuel pump module and also supplies a varying voltage to the fuel tank fuel pump module in order to maintain the desired fuel line pressure.
The fuel system is an electronic returnless on-demand design. A returnless fuel system reduces the internal temperature of the fuel tank by not returning hot fuel from the engine to the fuel tank. Reducing the internal temperature of the fuel tank results in lower evaporative emissions.
An electric turbine style fuel pump attaches to the fuel tank fuel pump module inside the fuel tank. The fuel pump supplies fuel through the fuel feed pipe to the high pressure fuel pump. The high pressure fuel pump supplies fuel to a variable-pressure fuel rail. Fuel enters the combustion chamber through precision multi-hole fuel injectors. The high pressure fuel pump, fuel rail pressure, fuel injection timing, and injection duration are controlled by the ECM.
Diagnostic Aids
Observe the Misfire Counters or perform the Fuel Injector Balance Test to help identify a leaking Fuel Injector. Refer toFuel Injector Balance Test.
Reference Information
Description and Operation
Fuel System Description
Electrical Information Reference
Scan Tool Reference
Control Module References for scan tool information
Special Tools
CH–37287–1A - Fuel Pressure Gauge Adapter
For equivalent regional tools, refer to Special Tools.
Note:
  • Repair all fuel system related DTCs before performing this diagnostic.
  • Inspect the fuel system for damage or external leaks before proceeding.
  • Verify that adequate fuel is in the fuel tank before proceeding.
  • The Fuel Pump Enable may need to be commanded ON a few times in order to obtain the highest possible fuel pressure.
  • DO NOT perform the Fuel System Diagnosis if the engine coolant temperature is above 60°C (150°F). High fuel pressure readings may result due to hot soak fuel boiling. With the engine OFF, the fuel pressure may increase beyond the pressure relief regulator valve's setting point of 690 kPa (100 psi) ± 5 percent.
Note: The fuel pressure may vary slightly when the fuel pump stops operating. After the fuel pump stops operating, the fuel pressure should stabilize and remain constant.
Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage.
  1. Ignition ON, engine OFF, command the Fuel Pump Enable ON several times with a scan tool.
  2. Verify the scan tool Fuel Pressure Sensor parameter is between 320–580 kPa (46–84 psi) with the fuel pump running.
    • If less than 320 kPa (46 psi)
      Refer to Circuit/System Testing — Fuel Pressure Low.
    • If greater than 580 kPa (84 psi)
      Replace the G12 Fuel Pump.
    • If between 320–580 kPa (46–84 psi)
  3. Verify that the fuel pressure decreases to 468–544 kPa (68–79 psi) after the fuel pump is turned off.
    • If the fuel pressure does not decrease to 468–544 kPa (68–79 psi)
    • If the fuel pressure decreases to 468–544 kPa (68–79 psi)
  4. Verify that the fuel pressure does not decrease greater than 34 kPa (5 psi) in 1 minute.
    • If the fuel pressure decreases greater than 34 kPa (5 psi)
      Refer to Circuit/System Testing — Fuel Pressure Leaks Down.
    • If the fuel pressure does not decrease greater than 34 kPa (5 psi)
  5. Relieve the fuel pressure to 69 kPa (10 psi), refer to Fuel Pressure Relief.
  6. Verify that the fuel pressure does not decrease greater than 14 kPa (2 psi) in 5 minutes.
    • If the fuel pressure decreases greater than 14 kPa (2 psi)
    • If the fuel pressure does not decrease greater than 14 kPa (2 psi)
  7. Operate the vehicle within the conditions of the customer’s concern while monitoring the Fuel Pressure Sensor parameter with a scan tool.
  8. Verify the fuel pressure does not drop off during acceleration, cruise or hard cornering.
    • If the fuel pressure drops off
      Refer to Circuit/System Testing — Fuel Pressure Drops OFF.
    • If the fuel pressure does not drop off
  9. If the fuel system components test normal, refer to Symptoms - Engine Controls , Fuel Injector Diagnosis , and Fuel Injector Balance Test for further diagnosis.
Fuel Pressure Low
  1. Verify none of the conditions listed below exist:
    • Restricted fuel feed pipe
    • Restricted or plugged strainer
    • Poor connections at the fuel pump harness connector and the ground circuits.
    • If a condition exist
      Repair as necessary.
    • If a condition does not exist
  2. Test or replace the G12 Fuel Pump.
  1. Ignition OFF, relieve the fuel pressure. Refer to Fuel Pressure Relief.
  2. Install the CH–37287–1A - Fuel Pressure Gauge Adapter between the fuel feed pipe and the fuel rail.
  3. Open both of the valves on the CH–37287–1A - Fuel Pressure Gauge Adapter .
  4. Ignition ON, command the Fuel Pump Enable ON with a scan tool.
  5. Close one of the valves on the CH–37287–1A - Fuel Pressure Gauge Adapter .
  6. Verify that the Fuel Pressure Sensor parameter does not decrease greater than 34 kPa (5 psi) in 1 minute.
  7. Locate and replace the leaking Q17 Fuel Injector.
    • Poor connections at the Fuel Pump harness connector and the ground circuit.
Quote
The engine control module (ECM) supplies a separate high voltage supply circuit and a high voltage control circuit for each fuel injector. The ECM initially opens each fuel injector with 65 V. This high voltage is controlled by a boost capacitor in the ECM. During the 65 V boost phase, the capacitor is discharged through a fuel injector, allowing for initial fuel injector opening. The fuel injector is then held open with 12 V. The ECM varies the amount of time each fuel injector is open to provide proper combustion under all engine load conditions.
A fuel injector coil winding resistance that is too high or too low will affect the engine driveability. The fuel injector coil windings are affected by temperature. The resistance of the fuel injector coil windings will increase as the temperature of the fuel injector increases.
Schematic Reference
Engine Controls Schematics
Component Testing
Note:
  • The resistance test must be performed at the fuel injector or mis-diagnosis will occur.
  • The DMM and test leads must be calibrated to 0 Ω in order to prevent mis-diagnosis.
  1. Test for 1.06 Ω +/− 10% @ 20°C (68°F) between the high voltage supply circuit terminal 2 and the high voltage control circuit terminal 1 at the Q17 Fuel Injector.
    • If not within the specified range
      Replace the Q17 Fuel Injector.
    • If within the specified range
  2. Test for infinite resistance between each terminal at the Q17 Fuel Injector and the Q17 Fuel Injector housing/case.
    • If not infinite resistance
    • If infinite resistance
  3. All OK, perform the Fuel Injector Balance Test.
Repair Instructions
Perform the Diagnostic Repair Verification after completing the repair.
Fuel Injector Replacement
I posted fuel system and fuel injector diagnostics.
They are from a subscription site.
It is critical to use genuine OEM injectors and not counterfeit or aftermarket parts if you determine injectors need replaced.
Edited by asilverblazer
Quote
Two methods of testing fuel injector balance are available, the Active Fuel Injector Tester (AFIT) or a scan tool. The Active Fuel Injector Tester and SIDI adaptor connects to the engine control module harness connectors to test the high pressure fuel pump performance, fuel injector wiring, and fuel injector operation. The AFIT displays step by step instructions to precisely determine pressure drop of each fuel injector. The scan tool fuel injector balance test is performed while the engine is running at idle. The scan tool pressurizes the fuel rail to a predetermined pressure before each fuel injector is pulsed for a precise amount of time allowing a measured amount of the fuel to be injected. This causes a drop in the system fuel pressure that is recorded and used to compare each fuel injector.
Diagnostic Aids
  • Monitoring the scan tool Cylinder 1 -8 Current Misfire Counters may help to isolate the fuel injector that is causing the condition.
  • Operating the vehicle over a wide temperature range may help isolate the fuel injector that is causing the condition.
Schematic Reference
Connector End View Reference
Component Connector End Views
Scan Tool Reference
Special Tools
  • CH-47976 - Active Fuel Injector Tester
  • CH-47976-500 - Active Fuel Injection Tester (AFIT) SIDI Adapter Kit
  1. Ignition ON.
  2. Verify the scan tool Fuel Remaining parameter is greater than 10%.
    • If the Fuel Remaining parameter is less than 10%, add fuel to the fuel tank.
    • If the Fuel Remaining parameter is 10% or greater
  3. Verify the scan tool ECT Sensor parameter is less than 60°C (140°F).
    • If the ECT Sensor parameter is greater than 60°C (140°F), allow the engine temperature to cool.
    • If the ECT Sensor parameter is 60°C (140°F) or less
  4. Verify the battery is fully charged and all accessories are Off.
    • If the battery is not fully charged, charge or repair battery as necessary.
    • If the battery is fully charged
  5. Preform the appropriate Fuel Injector Balance Test in Circuit System Testing.
Fuel Injector Balance Test with Active Fuel Injector Tester
  1. Ignition OFF, all vehicle systems OFF. Install the CH-47976 - Active Fuel Injector Tester and the CH-47976-500 - Active Fuel Injection Tester (AFIT) SIDI Adapter Kit , refer to the Active Fuel Injector Tester User Guide. It may take up to 2 minutes for all vehicle systems to power down.
  2. Turn ON the Active Fuel Injector Tester and select the vehicle.
  3. Ignition ON, perform the Injector Test with the Active Fuel Injector Tester.
    • If the Active Fuel Injector Tester aborts testing due to fuel pressure or fuel leak down
    • If the Active Fuel Injector Tester does not abort testing
  4. Compare the test results with the appropriate recommended tolerance.
    • If any fuel injector exceeds the recommended tolerance
      Replace the appropriate Q17 Fuel Injector(s).
    • If all fuel injectors are within the recommended tolerance
  5. Perform Fuel Injector Circuit Diagnosis.
Fuel Injector Balance Test with Scan Tool
Note: The engine speed must be between 600–1,000 RPM to perform this test.
Note: For engines with 2 banks of cylinders, only measure average pressure drop on cylinders that are on the same bank.
  1. Ignition ON.
  2. Command the Fuel Pump Enable ON with a scan tool.
  3. Verify the fuel pressure is between 320–580 kPa (46–84 PSI) with the fuel pump running.
    • If within 320–580 kPa (46–84 PSI)
  4. Verify the fuel pressure does not decrease greater than 34 kPa (5 PSI) within 1 minute.
    • If less than the specified value
  5. Engine idling.
  6. Verify the scan tool Fuel Rail Pressure Sensor 1 parameter is between 1.9–5.0 MPa (276–725 PSI).
    • If between 1.9–5.0 MPa (276–725 PSI)
  7. Select the Fuel Injector Balance function within the Control Functions menu of a scan tool.
  8. Select and test a Q17 Fuel Injector. Repeat for each Q17 Fuel Injector.
  9. Obtain and record a pressure drop value for each Q17 Fuel Injector.
  10. Add all of the individual pressure drop values except for the fuel injector suspected of being faulty. This is the total pressure drop.
  11. Divide the total pressure drop by the number of fuel injectors that were added together. This is the average pressure drop.
  12. Multiply the average pressure drop by 0.20. This is the acceptable variance from the average pressure drop, 20%.
  13. Verify the difference between any individual pressure drop and the average pressure drop is not greater than the acceptable variance.
    • If greater than the acceptable variance
    • If within the acceptable variance
  14. Perform Fuel Injector Circuit Diagnosis.
  • 3 weeks later...
If you look at the fuelpressure which is around 360 kpa in the freezeframe,  do you guys think it is a bit low? And what about the fuelrailpressure?
I think those are both with in spec.
It seems that the check engine light only comes on when I do short trips of 3 miles or less. Like going to the supermarket at the other side of town and give grandma a lift😁. When I do longer trips of like 60 or 80 miles it has no issues at all.
The coolant temperature hits 210°F at these short trips, especialy now it's summertime and the outside temperature hits 80°F or more.
I'm trying to apply the systemtest of
Asilverblazer but I'm still learning/ experimenting how all of the tests work in combination with hptuners.
  • 1 year later...
I didn't had much time to do any testing on the truck past year. But I started again to solve the problem once and for all.
I think the high pressure fuel pump is a bit faulty. I did some testing to see if the long and short term fueltrim is ok.
With the engine warmed up I
first plugged the crankcase ventilation to see if the long term fuel trim stays in spec. It read -3.9% at idle.
Then I connected the crankcase ventilation and it read -10%. (Bank 1 and 2 read about the same percentage) So I think the high pressure fuelpump is leaking fuel in the oil.
When I turn on the ignition to check the fuelpressure it stays at 250 kpa. And at idle it bounces around 250 kpa and 460 kpa. Even at 3000rpm it doesn't go above maybe 380 kpa.
And the fuel rail pressure reads 400 to 500 kpa.
So I think I'm going to replace the high pressure fuel pump. It could be a faulty injector but because the fuelpressure is a bit low I think the best way to go is change the fuelpump.
What do you guys think?
    • Yes I agree, its what amounts to free advertising to let people know about his UOA testing company, and not that there is anything wrong with that but certainly that is a motivator for putting out videos about the science of oil as well as other topics such as oil and air filtration etc. The interesting part I found with his last video is not only the physics behind the reason for the varying wear due to a diesels working torque range causing more bearing load and that higher viscosity oil is of benefit, it was also that the chemistry behind the GM Dexos 0W-20 and the Mobil Dexos licensed 0W-20 are far enough apart that its showing up with a difference in wear even though the two oils are matched in viscosity and in that comparison viscosity was not having the finger pointed at it.    There are a few youtubers out there or one anyway that I have watched a bit of who has gone through the pains of accessing various countries manuals for a certain engine platform and while in the US/Canada it may say use 0W-20 or what have you for some Toyota product, in some other countries it sings a very different tune for the very same engine with the typical traditional oil viscosity/ambient temperature charts to help choose which oil viscosity is correct for the conditions the vehicle will be used in and in some cases its taken an engine in a US manual that states only use 0W-20 as per warranty coverage and yet that same engine in certain other countries may have up to a 15W-40 etc oil option that meets the spec. Another words the guy who is driving through Death Valley or Phoenix and south weather at 120f is often being fed a line of bs by the US system that has forced vehicle companies to restrict the warranty to a specific low viscosity oil for anterior reasons as well as the long drain interval suggestions.    Thankfully youtube is free ( yet anyway ) for viewers to sift through information and of course comes with the good and the bad ( truth and lies ) and we can choose to turn off/not watch what a person finds is bs or just not interested in the topic.
    • No doubt... But, as someone who doesn't pay for his services, but who has provided a few views/clicks on his Youtube platform, the data around the Mobil oil testing I think does have some value including to "freeloaders" like me.   A lot of what he's doing is likely showing the OE's work in their oil selection, something that many of us had kind of assumed was true all along, a good balance of both excellent protection and efficiency.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
    • I agree with this assessment. As you know I’m testing longevity with vehicles for the first time. I have a few vehicles I passed to kids and grandkids. We’re all past 100K miles some approaching 170K. I’m the only one doing 5k oil changes. The rest whatever the minder says. I’m the only one doing frequent transmission service. My odyssey the trip vehicle at 200K will be finished as a trip vehicle. I recently changed to high mileage oil, Valvoline. I can’t get past the fact that all manufacturers want to claim long service life. I just don’t make sense that they would go with low weight oil for mileage. While sacrificing longevity.
