I want to force the dealer to update mine because it's getting worse and worse. I no longer have parking lines on my cameras for some reason... But I don't want to make things even worse.
Have you tried a hard reboot? Press and hold the hangup button until the system power cycles.
Thanks, I already have to do that a few times a week just to keep things partially functional.
On 11/1/2024 at 11:35 AM, White LTZ said:
I went this morning for the update.  I was there for a little less than two hours.  According to my paperwork I received the update ending in -05.  As mentioned here this apparently does not include the radio update as I still have Android 10 and versions that are over two years old.
Got mine back today.
Was gonna post pics, but the info is exactly the same as these two pictures that White LTZ posted.
Work Order says N242435631  -- but does not indicate a dash with a revision number
Description for it says Serial Gateway Module and Radio.
There is also a wcc number listed --- I don't know what a wcc number is...
Also had recall repair -- N242447990  Failed Brake Fluid Leak Detection
(who new there was a brake fluid leak detector??)
This is Brake System Control Module Reprogramming with SPS  ...and it gives a different wcc number...
This truck also needed a new battery, which was also installed.
So far everything still seems to be working correctly.
All settings seem to have been retained.
Seems to be working as before.
I could care less about the Android version number, it works (on the rare times I activate it) so that's all that matters.
I wish we never needed the extra layer.
So far, haven't discovered any downside to the update.
The "Android version number" is the base operating system for the Infotainment system and is part of Android Automotive (which is NOT the same thing as Android Auto). Every time you start the truck, that software loads and shows you things like radio info, the clock, and anything else on the display but it also operates the radio, HVAC, parking sensors, stop/start, and a bunch of other stuff. It's actually fairly important to keep this up to date for general operation of all kinds of things as well as ensuring that the latest security patches are installed.
So now I'm curious. What version should it being showing for "Android version number"?
Am I looking at the correct thing, but calling it by the incorrect name?
Truck currently says there are no outstanding updates .... which is what I would expect after the dealer updates just completed.
Edited by redwngr
Mine is showing Build Number full_gminfo37_gb-user 12
My kernel version is 4.19.255
And my security patch level is Feb 5, 2024
None of these are the most current ones and are ALL slightly older than ones posted by others in this thread. However, like you, my truck shows no updates available and I suspect that the specific builds that are newer that some other folks have is likely related to specific trim levels or features that they have that I do not. In other words, I don't like how GM handles their software and updates (they are HORRIBLE at this), but there's nothing I can do to force a newer build onto my truck so I'm good with it.
On 10/11/2024 at 4:14 PM, NW-Shadow21 said:
Had mine updated last Tuesday,now android 12 and version 175.5 all seems well
Which year and specific model truck do you have? [Edit: N/M, I see in your profile]
Edited by ormandj
I had it performed on my 2023 Denali and now it will not read back my text messages.
Any chance the factory recall for software update N242435631 "serial data gateway module" will fix the erratic windshield wiper issue? This update is for the radio and serial communication firmware. Doesn't sound like this software update has been going very smooth by looking at the posted information on this recall. It is potentially causing more problems than it solves. I'm taking my time getting the update in hopes more bugs get worked out by the software engineers.
I'm not aware of any changes to the SOFTWARE that they are installing. The only thing that I know that has changed has been whether or not they do any software updates (i.e. radio) beyond the module. They updated the Infotainment system in my truck and it did fix a couple of issues, but I now have new problems that were actually supposed to have been fixed by this update. SMH
And totally as an aside - what the hell is the point of offering a wireless charger in these trucks if it doesn't work? We took an hour's drive last night, using Waze / Android Auto, and my phone refused to stay in a charging state for most of the drive no matter what I did. Every so-called "fix" that has been offered is not an actual fix for whatever is wrong with this thing - it's clearly something related to how it interoperates with phones and there's no rhyme or reason to why the charging mode stops and there is no additional information available for the purposes of understanding the problem.
What is the erratic wiper issue?
Do you have the rain-sensing wipers?
I know what he means,my 2024 LT 1500 has this issue.  Glad to see it just not me. Just out of the blue you use the turn signal and wipers cycle.  Sometimes once or 3 times.  Seems if I turn on signal down towards steering column it don't do it.
On 11/3/2024 at 1:54 PM, sabbotage said:
I had this recall done in late August shortly after it came out because the gauges don't always come on in my truck when I start it and was hoping maybe this would fix that as well.  Only the speedo and RPM gauges don't come on.  I have to flip to display settings and change the gauge layout and then back to the one I use and then they come on.
Anyway, my infotainment is on Android 12 and the version I have is Y172.6.1.  I only have one annoying issue since I had it done to mine.  My infotainment system always now does a super slow startup (regardless what the startup setting is set to) and I hear the Android screen unlock sound every time I start my truck before the screen loads.  It sometimes takes close to a minute to fully boot up.  I disconnected my negative battery terminal a few times and that seems to fix it for a day or 2 and then it goes back to the same issue. I even factory reset my system and set it all up from scratch last night and went out this morning with the same slow startup issue.   I haven't noticed any other negative effects.
I have the same speedo and RPM non appearing issue. I have found that if I wait till the infotainment center is longer into it's boot up sequence that it does not happen. But if I get in the truck and hit the start button just as the radio screen is booting up, I can get the issue to happen every time. But I also noticed it does not happen if truck was started up recently. It seems to happen when truck sits over nite and on the first cold start up the next day. And I fix it the same way you do. I got the recall done 11/19/24 and my build number did not change from what it was before and I'm, still at Android 10.  I'm on the fence about pushing for the android 12 update because of all the problems I see on this forum with it. Now that I know if I just wait another 2 seconds before starting my truck up, the speedo and rpm gage will work.  Question, since your at level 12 and build number at 172.6.1, have you had the speedo and rpm issue anymore?
That's caused by changing the intermittent wiper setting. I had this same issue and discovered it's because you're slightly rotating the intermittent settings enough that it registers a change. The wipers wipe once if you change it one notch - try it manually and you'll see. The switch doesn't even have to be moved to a new position fully, it will register a change with a slight movement that leaves it in the same position.
It's just a really bad physical placement of that control on the turn signal stalk, and a strange implementation of auto-wipers where you need that intermittent setting enabled in order to turn on auto wipers vs. a dedicated button.
Edited by ormandj
  • Thanks 2
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
    • https://www.msn.com/en-us/autos/news/fuel-economy-stickers-don-t-tell-the-whole-story-aaa-data-reveals-why/ar-AA26ocHk?ocid=winp2fptaskbarhover&cvid=6a4122ea3dae47e5b8dfbed5d4fd3d55&cvpid=648f6b4fc2fa4eddb4c12893aeb957ed&ei=59
    • What’s missing in all this is patience and investment in the future. Buy a 170K starter home. Ten years later sell it invest in a more expensive home. Eventually you’ll have a 600K home and pay starter home payments. Buy a starter car. Maintain it well. Save the payments after it’s payed for then buy an expensive car if you desire. Buy a tumbler make your own coffee, pack your lunch. Cook your own dinner. Most importantly take care of your car.
    • People mislead themselves. Statistics are highly useful indicators.   Here's the tie-in to this thread. If an oil sample tests shows a wear indicator of 7 using cheaper ACDelco oil, and a wear indicator of 2 (lower = less wear) using a particular brand of Mobil oil, and wear has a linear relationship with engine lifespan, anyone could assume that Mobil is reducing wear by more than 50% (let's just say a 200% reduction for you red state people trying hard to do math) which leads to increasing engine life by 2x. Perhaps, in a vacuum, by itself, when dreamed by AI.   Yeah?! That's what the statistic is saying, isn't it?   No, it isn't. It didn't come out and say engine life is doubled. That's a very bad assumption, and a case of severe myopia by assuming something potentially untrue about the only data point in focus.   Average cost of a new car is 50k. You bet it is.   The median cost of a new car is more like 35k. Expensive cars are skewing the perception that "average" now means a $50k price of entry for a very average automobile. And that's not true. People who don't understand statistics twist the living heck out of them to mean all sorts of things they don't actually mean.   "Average" new car payment is $1000/month. Yep, it is. And in that number are all the $35k new car buyers who bring significant equity, and the $25k new car buyers who finance the car for a month just to get a rebate, and then pay it off. Know what isn't in that number? All the payments made by people who don't finance a car.   Picking one's own data point (don't have a car payment, never paid $50k for a new vehicle, my house cost $170k, I afforded a middle class lifestyle on $4.50/hr) is just a data point. Just like earning $25/hr in an area where the median home price is almost $1 Million is a data point. In fact, it's a lot of data points given that 80% of the US population lives in/around major cities. They're not idiots; the vast majority of them do it to make a living because that's where the big money is.   The highs have become higher, lows have become lower, and how your personal mileage varies is not truth for an entire country. At the same time you can't NOT acknowledge the data. While it doesn't paint YOUR personal picture, it certainly tints the reality that you also live in, as does your single data point.
