my rear right tire is not communicating  and triggers an errror every time i start... it was occasiional but now with the cold weather its been permanent... im figuring battery..  are these batterys changable? is it something i can do myself? never dealt with them.. but its hard to get to a tire shop when you work all day.. i do have the old horror freight tire mcahine so if its doable i might give it a try?..
Battery is about dead. I change these on my vehicles myself, pretty simple to do. Go on Amazon and order some new ones you can get them for around $20 - $30 for four. They are vehicle specific so make sure you get the right ones. You'll also need the relearn tool usually about $10.
so you change the whole sensor and not the batttery?  ive never looked at them. only issue i would have is rebalanceing the wheel to the rim if i do it myself..
Right you change the whole valve. You only have to break the valve side of the tire down. If you don't rotate the tire on the rim no need to rebalance.
You replace the whole sensor.  Just need to break the outer bead and push it down enough to service the TPM sensor and valve stem.
Edited by newdude
ok i'll have to look on amazon... easier to try it myself then get to the tire shop...when there open.  so i assume they come in 4 packs?  only 1 giving me issues at this time.  thnks
The others aren't too far behind the first!  BTDT!
I bought 4 new GM OE sensors for $45 off ebay and paid my local tire shop $80 to install them AND balance and rotate the tires for me.  Saved my back.
so how do i know what model i need so i can order it b4  i tear into the tire? i see many options on amazon. there around 50 cdn for 4  and the coding tool is like 18cdn.. did gm always use the same part in the 1500 for the 2018 year or is it a gamble till i pop the tire and look?
If you use Amazon just type in tpms sensor for 2018 Silverado in the search bar and all options will come up. It will say if it fits your vehicle.
I had the same issue on my 2017. The dealership tried to reset the TMPS and no change and they quoted almost $300.00 to replace one of the sensors. The service representative said it is ridiculous what GM charges for the sensors, and he quietly recommended that I get the sensors from eBay. The dealership wanted almost $100 per sensor, but I got all four GM (13540604) sensors for $118.96. I decided to replace all four, so I don't have to deal with this again. You can check the RPO codes that are listed in the glove box. My truck's TPMS RPO code is XL7 (Tire Pressure Monitor Sensor - FREQUENCIES RATING 315 MHZ).
Hope this helps.
Will bad sensors send an abs system warning to the "my chevrolet" app on my phone? The rear 2 sensors suddenly started reading nothing on my 2018 silverado today while I was driving. Got a tpms warning on the dash, but the app showed an abs system warning. Tire pressures are all good.
  • Confused 1
I have the exact same issue. Sensor went bad and now all of a sudden I get the ABS alert in the myGMC app after driving it. Once the truck sits for a bit after driving, the ABS alert goes away in the app. No alerts at all in the truck. It’s all in the app.
I’m not getting any codes either when plugging in the OBD II reader. As long as I’m not getting any codes or lights on the dash I’m not going to worry about it. Yet.
  • Confused 1
Tire pressure sensors won't set an ABS light/warning message.  They'd set a tire pressure light/warning.
But if the app has the TPMS as part of the ABS system, that could be a why it shows up under that warning message. Some vehicles may have the TPMS integrated with the ABS/Trac/Stabiltrak but while also being separate from the PCM/TCM reporting. I wouldn't worry about it though.
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
    • Kind of off topic, wife drives a 2023 Yukon Denali with the 3.0, been a great rig so far, incredible fuel economy for a truck that big and heavy. Coming up on 50000 trouble free miles.
    • I`m gonna try some of this in my 2000 LM7 that has had the famous piston slap since 17,000 miles or so. I have used Mopar combustion chamber cleaner down the spark plug holes a few times in the past. Corrects the problem for a few months or so. Then returns. GM top engine cleaner has been used also. No good results from this.   This LM7 never used oil. Even running the piss out of it.   Course, I`m gonna use this in my 2025 L84 while it`s still clean. It`s got 13,000 miles. Used Chevron fuel system cleaner [2 bottles in tank] a tank or 2 ago.
