Is there a place to get the update cheaper than the $149 on the GM site. I used to get an email with $99 deal but have not seen that in a few years. IMHO it should not be that pricey. $50 is reasonable.
I don’t them on. I use my phone it’s always up to date.
Same here.  I use Waze if I am traveling somewhere unfamiliar and need the turn-by-turn directions.  Waze is crowd updated so you can get info like accidents or road hazards in your direction of travel.  I sometimes use the GM nav if I need a quick view of street layouts in the area I'm in.  I agree, $50 or less would be more appealing to keeping the GM nav updated.
34 minutes ago, Black Smoke said:
How old is your truck?
Mine is a 2021. I usually update every 2 years. Wife relies on it as she does not like to use her phone. I have a Garmin 890 I use when camper is connected.
I use it too. Every in dash GPS I had has sun glare. Where I can position my phone to eliminate the problem.
I myself think that the cost to upgrade is very unreasonable and should be a courtesy with discounted upgrades. I'm on the road a lot especially in Texas with work and rely on Waze. I keep hearing Google maps is going to update to be more comparable to Waze. Some people I know use Waze but the majority use Google.
I have a 2020 and it seems like the GM Nav site has been "out of stock" for the last 2 years.  Interesting to see that it's available again.
Well I found on Amazon where I can get it for less than $40. Its just a sim card. There is not a 2025 update yet just the 2024. I will try this.
UPDATE: the SD card works and is recognized but it seems to be NOT the latest version of maps. Looking at the version info in the app, it appears to be the same as my 2022 version. Will have to return the update.
Edited by GMC4Zee
UPDATE
FWIW, I bought a NAV-Disc update off of eBay years ago for my Escalade and it worked fine.
If I recall, the Nav system update cards are VIN specific if they are from a legitimate source, so just make sure you're not paying $40 for a copy or knock-off that won't work with your truck. It's GM's way to keep us tethered.
Don't think the Nav-Disc has been used in years, starting with the K2's, it went to thumb drives like mentioned above, now using OTA's.
Its funny, if you go to the official site the picture they show is an SD card not a USB but that could be just old and not updated. Will let you all know. Is there a place I can see the current map update to see if I am going forward or backward?
My 2019 has the SD card for the map.  I just looked at the owner's manual for the GMC 2021 Sierra HD, and it says on page 167 the map database is stored on an SD card.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
