Message added by Zane,
Hey everyone, we noticed this question comes up a lot, so we finally put together one master cheat sheet. It covers the exact oil capacity, filter numbers, and drain plug torques for every GM truck and SUV from 2016 through 2026. Bookmark the full guide here so you never have to guess again: https://www.gm-trucks.com/gm-engine-oil-capacity-guide/
On my 22 duramax, it takes almost 11 qts. I inquired on another forum, there was a few that said their duramax takes more than 10 qts.
  • 3 weeks later...
On 5/20/2025 at 5:57 PM, 64BAwagon said:
I recently changed the oil in my new 2025 L5P Duramax along with a new PF63 filter. It took 11 qts to get the dipstick to read at the top of the full mark. I thought this was a 10 qt engine ? Could it be that the pan was revised for a more thorough drain ? Banks has been making a big deal out of the pan not draining completely.
Anyone else notice this ?
Did you check the level after the had been run and then sat overnight (or at least for a few hours)
Dmax is notorious for taking a long time to drain down.
Yes, I checked it a number of times including the next morning and it was still low until I added another qt. I guess I will know for sure in the spring when I change it again.
  • 3 months later...
When I have time I let mine drain for well over an hour, easily takes 10.5-11 qts.
  • 4 weeks later...
Call me crazy, but it sure seems my 2025 takes more oil than my 2020 did.  Just did my 3rd oil change on this truck and it took 11 quarts, but I always remember 10 on the 2020.  I let it drain 10-15 minutes, but not more usually.
10 quarts (2.5 gallon jug) fills my 2024 L5P just fine. Shows about 3/4 up the hash marks on the dipstick after filling and sitting for 30 minus or so. Don't overthink it. The fill capacity is 10 quarts.
Edited by fondupot
2.5 gallon jugs are nice, just have to be careful when putting it in. Not the lightest thing to handle.
Yea, and the hood scoop thingy on the driver side is positioned DIRECTLY over the fricken oil fill tube. I have to remove it every time and clean it out so debris doesn't fall into the tube. I have a funnel that twists into place on the fill tube tho making the fill a little easier, but it's always a little precarious filling up the oil with the 2.5g jugs while standing on a step stool leaning over the engine bay.
I like the CCV relocate kits on the market that also move the oil fill tube towards the front of the engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
