Has anyone noticed their power steering making a moaning noise when hard over either direction? Wondering if this is normal. I have never had a vehicle make so much noise when having wheel cranked. Almost like fluid not flowing correctly. I have not checked power steering fluid level if there is such a check.
Normal especially if it has the digital assist which pretty much every crew cab HD this gen 2020-2026 has.
Mine always has. I just back off a bit and it stops.
had 5 of these trucks since 2020 and yeah its just the nature of them when at hard lock, I dont even pay attn to it anymore
How would I check if my wt has that? Hopefully not I don’t like options.
I'm under the impression WT/Custom doesn't get it.
Yeah, my power steering flow sounds like it has air or rocks in it from day one… any pressure on the steering wheel in either direction it hisses and bubbles…sounds like this L8T is an L5P. I need to bring it to the dealer before the warranty runs out. From reading other responses though I’m afraid that’s just normal…. I guess the other option would just be to go test drive a comparable truck and see if it makes the same noise… but that still doesn’t fix it. I assume it is like others have said and related to the digital steering assist  (RPO code NV8).
Did find this though:
https://static.nhtsa.gov/odi/tsbs/2025/MC-11013018-0001.pdf
Edited by EXSlider400
For the 2020-2023 only the LTZ and above trim got the digital. Don't know about the 24+ but it's probably the same.
Use only PS fluid, not ATF. The system can be bled although it's potentially messy and doesn't look super easy. PS fluid expands so there is a cold and hot check mark just like the transmission. Check with engine running.
You want to really hear it groan? Strap a stabilizer and some 35psi 37" tires to it and do a slow speed full lock turn 😆
Our team would like to work alongside you during this process, to act as an extra layer of assistance between yourself and your dealership. So that we may learn more, we ask that you email us at [email protected] with "GM Trucks-EXSlider400". By sending us a message, you consent to the information you provide being monitored and recorded by GM or those acting on GM’s behalf, subject to the GM Privacy Statement:  https://www.gm.com/privacy-statement.
correct it is LTZ and above that get digital....had a 2020 and 2022 LT and it hissed and bubbled at full lock and only had std standard steering, owned a 23 HC and currently a 24 SLT both with the digital and don't notice it as much and or maybe just dont use full lock......could be I am just used to it though, the steering is definitely noticeable at slow speeds between the 2.... like a 1500 with digital..
I don’t recall ever needing to crank the wheel to full lock. Ever. So I’ve never heard anything out of the ordinary.
not that often but I have had to do it, streets are really tight where I live.....like the whole town was built for compact car, lol
Updating this topic a bit as I just noticed OP has in his signature that they drive a 2025 LTZ Trail Boss, so it would have the NV8 digital steering.
PIT5544H: Normal Characteristic - Hydraulic Rush Noise from Power Steering Gear - (Jan 24, 2025)
- LINK TO THIS PI - MC-11013473-0001.pdf
Thanks for the info....
    twgraham
    twgraham
  • Who's Online   5 Members, 0 Anonymous, 490 Guests (See full list)
    • Can someone tell me where the video processing module is in a 2023 Silverado? I'm getting conflicting results that it's in the front passenger area or the rear passenger area behind the seat.
    • Yes I agree, its what amounts to free advertising to let people know about his UOA testing company, and not that there is anything wrong with that but certainly that is a motivator for putting out videos about the science of oil as well as other topics such as oil and air filtration etc. The interesting part I found with his last video is not only the physics behind the reason for the varying wear due to a diesels working torque range causing more bearing load and that higher viscosity oil is of benefit, it was also that the chemistry behind the GM Dexos 0W-20 and the Mobil Dexos licensed 0W-20 are far enough apart that its showing up with a difference in wear even though the two oils are matched in viscosity and in that comparison viscosity was not having the finger pointed at it.    There are a few youtubers out there or one anyway that I have watched a bit of who has gone through the pains of accessing various countries manuals for a certain engine platform and while in the US/Canada it may say use 0W-20 or what have you for some Toyota product, in some other countries it sings a very different tune for the very same engine with the typical traditional oil viscosity/ambient temperature charts to help choose which oil viscosity is correct for the conditions the vehicle will be used in and in some cases its taken an engine in a US manual that states only use 0W-20 as per warranty coverage and yet that same engine in certain other countries may have up to a 15W-40 etc oil option that meets the spec. Another words the guy who is driving through Death Valley or Phoenix and south weather at 120f is often being fed a line of bs by the US system that has forced vehicle companies to restrict the warranty to a specific low viscosity oil for anterior reasons as well as the long drain interval suggestions.    Thankfully youtube is free ( yet anyway ) for viewers to sift through information and of course comes with the good and the bad ( truth and lies ) and we can choose to turn off/not watch what a person finds is bs or just not interested in the topic.
    • No doubt... But, as someone who doesn't pay for his services, but who has provided a few views/clicks on his Youtube platform, the data around the Mobil oil testing I think does have some value including to "freeloaders" like me.   A lot of what he's doing is likely showing the OE's work in their oil selection, something that many of us had kind of assumed was true all along, a good balance of both excellent protection and efficiency.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
