Has anyone noticed their power steering making a moaning noise when hard over either direction? Wondering if this is normal. I have never had a vehicle make so much noise when having wheel cranked. Almost like fluid not flowing correctly. I have not checked power steering fluid level if there is such a check.
Normal especially if it has the digital assist which pretty much every crew cab HD this gen 2020-2026 has.
Mine always has. I just back off a bit and it stops.
had 5 of these trucks since 2020 and yeah its just the nature of them when at hard lock, I dont even pay attn to it anymore
How would I check if my wt has that? Hopefully not I don’t like options.
I'm under the impression WT/Custom doesn't get it.
Yeah, my power steering flow sounds like it has air or rocks in it from day one… any pressure on the steering wheel in either direction it hisses and bubbles…sounds like this L8T is an L5P. I need to bring it to the dealer before the warranty runs out. From reading other responses though I’m afraid that’s just normal…. I guess the other option would just be to go test drive a comparable truck and see if it makes the same noise… but that still doesn’t fix it. I assume it is like others have said and related to the digital steering assist  (RPO code NV8).
Did find this though:
https://static.nhtsa.gov/odi/tsbs/2025/MC-11013018-0001.pdf
Edited by EXSlider400
For the 2020-2023 only the LTZ and above trim got the digital. Don't know about the 24+ but it's probably the same.
Use only PS fluid, not ATF. The system can be bled although it's potentially messy and doesn't look super easy. PS fluid expands so there is a cold and hot check mark just like the transmission. Check with engine running.
You want to really hear it groan? Strap a stabilizer and some 35psi 37" tires to it and do a slow speed full lock turn 😆
Our team would like to work alongside you during this process, to act as an extra layer of assistance between yourself and your dealership. So that we may learn more, we ask that you email us at [email protected] with "GM Trucks-EXSlider400". By sending us a message, you consent to the information you provide being monitored and recorded by GM or those acting on GM’s behalf, subject to the GM Privacy Statement:  https://www.gm.com/privacy-statement.
correct it is LTZ and above that get digital....had a 2020 and 2022 LT and it hissed and bubbled at full lock and only had std standard steering, owned a 23 HC and currently a 24 SLT both with the digital and don't notice it as much and or maybe just dont use full lock......could be I am just used to it though, the steering is definitely noticeable at slow speeds between the 2.... like a 1500 with digital..
I don’t recall ever needing to crank the wheel to full lock. Ever. So I’ve never heard anything out of the ordinary.
not that often but I have had to do it, streets are really tight where I live.....like the whole town was built for compact car, lol
Updating this topic a bit as I just noticed OP has in his signature that they drive a 2025 LTZ Trail Boss, so it would have the NV8 digital steering.
PIT5544H: Normal Characteristic - Hydraulic Rush Noise from Power Steering Gear - (Jan 24, 2025)
- LINK TO THIS PI - MC-11013473-0001.pdf
Thanks for the info....
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
