I've run Seafoam in oil on several of my cars. '17 silverado 5.3 (with 5W30) & a several bimmers. In my opinion, it's a good way to keep piston rings clean.i have not seen any issues. I've watched videos on YouTube on this subject. Seafoam says you can run it in the oil full time, iirc.
Here's a picture of my '05 BMW 3.0L top end after 100k miles using Seafoam.
Edited by rav3
  • Like 3
You should look into Valvoline Restore and Protect oil. It has shown excellent cleaning properties
  • Like 5
I've run Valvoline P&R 3W30 as well.
https://sandx.us/wp-content/uploads/2025/10/Seafoam-Motor-Treatment.pdf
Sections #3 and #9 and #14 are informative. Light distillates and Isopropanol. Likely, given the density and flammability hydrocarbons, in the kerosene/diesel range. The alcohol is the only polar component in it. So it works mainly as a dilutant.
It will depress the viscosity of the oil you are using. Significantly? Not at the stated treat rates but given oils that will shear out of grade (many), it will push a few more out. Component viscosities run 1.3 to 6 cP. Is that harmful? Depends who you ask and what mood they are in.
Dad used to flush motors with Kerosene and a little Type F ATF  and everyone told him all sorts of 'bad' would happen. Now light fractions are packaged; and it just fine? 😏
Most cheap motor flushes use some sort of this game plan. Most don't tell you to run it consistently and constantly.
Kerosene is cheaper and the alcohol useless in oil. Flashes out on the first heat up. I'm old enough to remember guys washing their hands in gasoline to remove oils/greasy deposits. (Please don't do that) Seafoam works the same way. Like cuts like.
It most certainly will NOT remove carbonized ring deposits made mainly of coked VM polymers. Will dilute soft deposits and 'aid' in flushing. If you motor is that bad......
3 hours ago, countryguy1717 said:
Anyone ever run seafoam in their oil before an oil change? Just curious if you saw any benefit or had any issues.
Valvoline Restore and Protect.
I have a 2009 Vibe I picked up on the cheap going on a year ago now.  Has the 2AZ-FE Toyota 2.4 under the hood which is well known for oil consumption due to the rings Toyota went with.  It was using 1 QUART in 400 MILES.  I am on the 3rd fill of R&P, oil consumption has reduced to 1 quart in 2000 miles.
Stuff works.  You won't really see a change until about oil change 3 or 4 per Valvoline, and I would agree with that.  The 2nd fill I was down to about 800mi/quart of oil.  Fill 3 is where its really taken effect.  I've seen the endless threads of 2.4 2AZ-FE owners trying all sorts of magic like Seafoam, Berrymans, etc.  Berryman seems to work good, Seafoam doesn't seem to dent them.
Best part about R&P is that you can run it all the time if you wish.  It is not a temporary use oil to resolve an issue, it can be used to keep the issue at bay long term.
Edited by newdude
  • Like 4
  • Thanks 1
Shorter OCI's fixes many issues.
  • Like 3
  • Thanks 1
Curious. How many miles did the motor have on it when you first started using the R&P and how long you running each batch?
234,XXXmi when I bought it, has 242,5XXmi right now.
Not a typo!
Every 3000mi on the drain interval for now, probably won't take it much past that.
Edited by newdude
  • Like 3
  • Thanks 1
10 hours ago, Grumpy Bear said:
 . . . I'm old enough to remember guys washing their hands in gasoline to remove oils/greasy deposits . . .
Still do, Grump! :cheers:
  • Haha 1
Not a typo!
PM me as your research unfolds please. I'd like to see where this tops out. Thanks!
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
