Following up on the dealer reveal article from earlier this month, we were passed some details that dealers heard at their annual meeting a few weeks ago.
I want to preface this by saying this is still unconfirmed, spotty intel.  BUT... Here is the breakdown of what we are hearing:
  • The 6.7L Rumor now seems unlikely: The gas engine lineup was confirmed to be a 5.7L and a 6.6L V8. No power figures yet, but it looks like Chevy is bringing back the iconic 350-cubic-inch displacement.
  • 1,000-Mile Range Duramax: A surprise detail- GM is targeting a staggering 1,000-mile driving range on a single tank for the light-duty 3.0L Duramax. What would that take to pull off?
I just published a full breakdown on the front page with a deeper dive into the fuel capacity math here:
https://www.gm-trucks.com/2027-chevy-silverado-leaks-5-7l-v8-1000-mile-range/
What does everyone think?
I think you are right with the 36-gallon tank. I see it as an option and not the standard. Just bragging rights for advertising to put out there.
I had an 100 gal fuel tank in the bed with my diesel trucks. I could go forever except when I was pulling my tractor. Going long distances is great except when you have to pee. So you have to stop anyway. I usually toped off with fuel while I was there. Stretch my legs.
Loved my Square body’s with dual tanks. Then switched to Suburbans with 40 gallon tank. Almost cried when I bought my 08 and they didn’t offer the bigger tanks. We all don’t use our trucks for school kids and grocery shopping
I have a 2021, 3.0 diesel and I love it.
I have 212,000 miles on it and it drives like it is brand new.
I would very much be interested in the 36 gallon tank.
If i could, I would do a 35 gal tank on my 2025.
With 1000 mile range, I can pick where i get fuel and where i stop to stretch.
All looks fantastic on paper, as they usually do! If they offered that engine to the aftermarket alongside the new truck, that would be fantastic, too.
The bigger question is, can GM build this thing and make it RELIABLE? Based on their past 19 model year track record, I have serious doubts.
Side note - I have a '93 Ram W250 with a Cummins that has a 1,600+ mile range. The stock 30 gallon tank, plus I've got a small toolbox that is mostly fuel - 91 gallons to be exact. :)
1,600 is as far as I dare go. Theoretically I should be able to go 1,900 before it stops running.
Edited by Jsdirt
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
