2007 SLE DIC Upgrade
Hi All,
I just got my new 2008 Sierra a couple weeks ago and so far I Love it! It has the 5.3 with AFM, 4.10 gears and the chrome appearance package from GM which includes the Grill, step bars and mirror caps. It also came with the 20 inch aluminum wheels. I have been reading this forum general information since I bought the truck and have ordered the DIC upgrade parts as well as a tonneau cover and a Line X is going to be sprayed on this week.
There sure are a lot of knowledgeable people here and some very sweet looking trucks from the pictures people are sharing. I haven't taken many pictures yet but I did try adding one to my avtar, hopefully it works! :chevy: (it seems a bit over exposed)
I will let you know how the upgrade goes when my parts arrive, and I'll try to post a better pic when I get a chance.
Thanks to all for the great information and ideas.
Al 8888
  • Replies 663
Ordered my DIC components form GMParsDirect.com for $55.44 for the DIC unit cluster and the dash panel.
I placed the order on April 10th and it arrived on April 23rd.
Here is the inside of the DIC panel:
Front:
Front of the hole:
The buttons:
Where the harness plugs into the DIC buttons:
The buttons simply pushed into the hole in the new panel.
DIC buttons installed in the dash panel":
Installed front:
The old panel was easy to remove, just pull gently and firmly around all the edges.
Old panel pulled from truck with harnesses attached:
The harness on the upper left is the 4-pin connector for the DIC which sits in false socket. The harness on the lower right is to the lighting control module:
The harnesses were removed and the lighting module was transfered to the new panel. Used a screw driver to help pry the retaining clips from the lighting module.
New panel with DIC buttons and lighting module installed and harnesses attached:
Install complete:
Everything went smoothly. Full installation took about five minutes. Fired up the truck and everything worked.
A few thoughts/comments/questions:
Works fine on the 4.8
I don't see a screen for real-time mileage (only for average).
When I turn on the truck, the DIC is blank until I press a button.
I know this was a little over detailed for something as simple as this. Hope it helps someone.
I think you only get real time milage with afm.
Nice How-To :thumbs:
I just did mine last week and it's not there. The screens I have now are;
-Odometer
-Trip
-Fuel Range
-Average Economy
-Fuel Used
-Timer
-Trans Temp
-Oil Life Remaining
-Units (English/Metric)
-Front Tires PSI
-Rear Tires PSI
-Trailer Gain
-Engine Hours
-Relearn Tire Positions
-Display Language
-Exit Lighting
-Approach Lighting
-Chime Volume
-Restore Factory Settings
If anyone wants a standard dash panel to play around with, I'm selling mine on ebay.
"Can be used as a back up or replacement for a scratched/damaged panel, or put a chain through the A/C vent and wear it as a stylish necklace."
Now that's funny.
  • 1 month later...
Hello All,
A Question for those of you that made the leap, has the addition of the instant MPG, or AFM indicator changed or altered your driving to get better mileage? My truck is a WT model and I'm generally a simple man but there are only minor clues when your in 4 vs. 8 cylinder mode.
Thanks!
I added this function and I really like it. I pretty much leave it showing the instant mpg and I've noticed that if I can see what a heavy foot is doing to my mpg that I tend to light foot it to keep the mpg's higher.
I hate my DIC :crackup:
Damn thing makes me realize how hard on the mileage I am. I can't even go > 80mph or tear off from stop lights anymore. :rolleyes:
That was the coolest thing when she got her 07 Impala.
So, I added my DIC yesterday. I can't believe that this just isn't included...stupid GM.
Anyway, thanks to all for the info on this forum!
I can't believe it's so simple...but the one thing I did get a kick out of, is the GM instuctions that come with it. 19 steps total, that basically include removal of ALL the panels around this one...which includes disconnecting the E-brake cable to remove the bottom panel. What a waste time it would be to do it that way!!!
I just bought mine from a GM parts dept. in the area (southern Alberta, Canada)...they are carrying them as regular stock as a lot of others are learning about this, and it takes 10+ business days to order in!
But call around! Every dealership has a different price!
And I do have AFM, and the Instant Fuel is active on mine...
I just ordered my DIC upgrade, I hope I don't break anything pulling the old panel off.
Not unless you try prying it with a crowbar or something...The clips are metal so unless they've rusted together or otherwise has been fused by welding, super glue, heat, etc they won't break easily. It'll take a bit of force to get it out, but I did it without breaking anything or cracking any plastic...I did scrape the edges a bit but not really noticeable at all.
I got it on about a week ago. Only took 5 min. and half of that was getting the old light switch out of the old one. :troll:
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
