My 08 Gmc 3500hd Handles Like Crap
I have a 2008 GMC 3500HD crew cab long box 4x4.since it was new I have noticed that the truck likes to wander on the road,especially on any highways that are rutted/dished/grooved out from where everyone drives!when you pull out to pass a vehicle the truck takes sharp jolts from left to right and it feels like the rear end is swaying!it almost feels like I have to drive the front end to keep up with the back end,or I am steering to keep up with the front wheels.I was told to have a 4 wheel alignment done which I did,and it didn't help!I have also been told it could be a steering issue and the front wheels are going where they want and I am having to make quick reactions to keep up!anyway I am out of ideas and my dealer can't come up with anything either!I am on my third crew cab long box so I know how these trucks handle and I have never expererienced anything like this before!it always does it on the highway regardless of wheather I am passing or just driving ,this truck is just all over the road,every passenger that has ever been in the truck has also felt this and we even stopped and checked all the lug nuts one day thinking a wheel was falling off,I have dropped my PSI from 80 in the rear to around 55 to try to help and think it is better but still unaceptable!any ideas?
How about the front pressure? If you are basically empty, 45-50 up front, 40-45 in back.
I have picked up my truck from the shop to have it handle like crap. Sure enough, 80 ALL THE WAY AROUND. And I thought this was a good shop. Now I do everything myself.
I had a 07 and it feeled like you discribed . I traded it in on another truck just for that problem. the day I was taking it in to trade i was cleaning the bed out. I lean across the bed to grab some tools when I heard and felt the back of the truck move. On my truck the rear leaf springs where sliding side to side on the front mounting bolt I grabed the side of the truck and shock it an you could see them sliding back and forth. My truck also had bad wheel hop somthing to check??
Have you put new tires on before this started? I had an issue with some tires the last time I bought some, if felt like you were always out of control. Took it back after about 90 days and talked to the tire guys and they replaced the two tires again and now 2 years and 30,000 miles later no problems. :lol:
    • Not sure about DFM tech but i know there's a stop/start deactivation button.
    • I could be interested if they axed cylinder deactivation and at least have a button for stop start. I’m sure the HP numbers will be higher. I would want a longer warranty to help build confidence. I’m a less is more guy as I get older. A V-8 work truck model would be my choice. I know a few outfitters for custom additions I prefer.
    • It's official. GMC pulled the covers off the next-gen 2027 Sierra 1500, and we got the first official look. Full breakdown here: https://www.gm-trucks.com/next-gen-2027-gmc-sierra-1500-v8-trim-changes/   The quick hits: SLE and SLT are dead. The new core retail trim is just called "Elevation". Two new V8s, a 5.7L and a 6.6L built with high-performance Corvette architecture roots. No horsepower or torque numbers yet. The 2.7 TurboMax finally ditches the old gearbox and gets the 10-speed automatic. AT4X moves to larger standard 35-inch tires with front and rear e-lockers, Multimatic DSSV dampers, and heavy-duty Jounce Control Dampers. Over 60 inches of combined display on Denali Ultimate and AT4X, complete with a motorized articulating center screen and an adaptive passenger screen. Seven simplified trims across the entire model line to clean up ordering confusion.   So let's get into it: New 5.7L and 6.6L gas V8s with custom active exhaust tuning and a Corvette connection. Is this the exact engine lineup half-ton traditionalists have been begging for? Purging the iconic SLE and SLT names after all these years to lean entirely on Elevation as the high-volume core. Bold move, or a mistake? That motorized articulating 16.3-inch screen that slides up to reveal a hidden dashboard vault. Awesome mechanical theater, or does it make you nervous about long-term durability? Physically lowering the headlamps in the front fascia to improve road courtesy and stop blinding oncoming traffic. Smart real-world engineering, or does it hurt the truck's aggressive stance? What trim are you putting your name down for on day one? Drop your first impressions below.
    • My overnight hospital stay turned into five.  I developed a post operative fever and an erratic  heart rate.  A blood clot in the lungs was the culprit.  This is apparently a common post surgical complication and easily remedied.   I was the youngest in a four bed ward and a Doctor with a Geriatric specialization was in charge of my care.  All of the nurses were good and some were outstanding at dealing with old people.  It was very evident that my age triggered a different level of care!  My advice to any senior going for a hospital stay is to have a trusted family member advocate visible.  If not, you will still be well cared for, but you may discover that your voice  isn't as strong as it once was!
    • $4.25 85 oct. in town, down 50 cents.
