Is your GMT-900 using oil
1,555 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
If it were me, I'd run 20W-50 if I were using that much oil.
The way I see it, the engine is pretty much junk anyway. Not going to hurt much running a heavier oil. I saw a big decline in piston and ring wear metals in my oil analysis by switching from 5w-30 to 10w-30. Even though the "10" is rating it's cold flow properties, it's an overall higher viscosity oil, which helped alot in my case.
I just wish I had started doing this right out of the gate
^that....as long as 20w is ok for your cold start ambient temps, you could run that and be ok.
come to think of it, it was probably the valve covers. That little occurrence was maybe 5 years ago, so my memory is a little fuzzy.
I was hoping that's what you meant. Thanks rob Roy!
Received my Range plug in today. It says not to leave it plugged in vehicles that are not driven daily. Battery drain is the reason. I only drive my truck in the weekends. I keep my truck on a battery tender, so I figure it's not an issue. But still, I'm curious. Do any of you have any issues with this?
Same here.
I'm running an Odyssey battery, but I don't think this thing draws that much extra to make a huge difference.
I just filled my tank the other day - last time I filled it was the first week of May, so that tells you how much it sits. I throw my charger on it at least once a month, or sooner if I remember. Had the Range for over a year now, and never a dead, or even weak, battery.
Edited by Jsdirt
Hello all, I need help. I've got an '11 Yukon 5.3 with AFM, 114,000 miles and it seems to be eating around 2-3 quarts every 3000 miles. Good or bad, I don't drive it much and never tow anything, so oil consumption is difficult to read. I do get the puff of smoke when I start it after driving it "hard" which really just means running it 75 mph or accelerating quickly.
What are my options? Should I just trade it in on a '14 or newer or what year doesn't have this issue?
I'm not a mechanic, but I take it to my small town mechanic where I live who I know and trust and they do good work. Should I have them do something to it to try to fix it?
I've only had it for about 8 months, man I wish I would've found this before I bought it. :(
When I have a new vehicle that burns oil, the last thing I'd want to do is trade it in on ANOTHER vehicle by the same manufacturer. If they can't get it right the first time, what makes you think a '14 or newer will be any better? I'd strongly suggest looking at Ram, or even Ford. Ram seems to have their crap together more than the other 2 ...
There's alot of options - none of them even remotely cheap, unfortunately. Could rebuild what you've got, drop a new crate motor in, tear it down and only repair the problem (which could be alot of things), drop in a used junkyard engine, buy a parts truck and do a swap, etc..
What you can afford will dictate which of those you choose. Junkyard engines are the cheapest route ... but that engine could be EXACTLY the same problem child as what you just yanked out ... only with more miles on it. Crate is the way to go, but HOLY CRAP wait until you see the cost of THAT ... then if you're paying someone to do the job, plan on another grand or more on top of all that. I HATE the LS engine ...
If you use it sparingly why buy again?
I would try a Range to disable AFM first or run it in manual in 5th gear so it can't engage AFM. Check back here for used or new for $200 I think. :happysad:
Edited by diyer2
The Range is great - I've had one for over a year now. Doesn't cure the oil burning, unfortunately. At least not in my case.
I should've said I love everything about this Yukon except the oil consumption, and I really don't mind that if the engine holds together and I'm not dumping a bunch of money into it for repairs.
I'll research this Range thing and maybe go with that. I'm guessing my mechanic would be able to install it?
How can I find out if damage is already done to the engine? What should I have my mechanic look into?
Thanks!
The Range just plugs into your data link connector under the steering column - anyone can handle that.
The oil burning in and of itself says the engine isn't right. Really not worth the diagnostic time ($$$) to find out the exact reason why. My guess is GM cheaped out on piston ring material, and it has worn out LONG before it should have ... or the piston/cylinder clearance is too large, also due to bad QC & manufacturing practices.
GM's priority these days is saving money. They could care less about the customer (or their own techs ... but that's a story for another day).
I loved the Range when I had it on my 2012. I would unplug mine once a month or when my truck would sit for a week (vacations). I used a strip of black electrical tape over hose LED lights- Hated that at night time.
Never had an issue though...
Edited by Bad Bowtie2
Thanks!
Definitely get a Range module, easy to plug in & out. It uses the data port plug down by your left knee (when your driving). Just add a strip of black electrical tape over the LED lights (trust me).
I would have the spark plugs checked/changed with AC Delco's, only run regular Dino oil & change it every 3 months/3K with an AC Delco Ultra Guard Gold filter. Also have him install an updated left valve cover- Improved baffle design.
Try all these out for a few oil changes & then let us know what your decision is...
    • I have a 2015 Silverado and sometimes I can not get in to the truck. I use the key to unlock the driver door. Something is locking the truck when I unlock it, last night I left the truck open and this morning it was locked with the mirrors folded in. This happens while driving so it is now a safety issue. I reach down for the folding button and they open, then they close again.  Any advice, thank you,   Ed
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
