2011 Sierra Leveling Kit
i am going to get a leveling kit for my 2011 sierra. i am finding kits 3", 2.5" 2", and 1.5". i know anything above 2" according to my measurements i took will make the truck sit higher in the front than the rear. so, even if i had to lift the rear, not a big deal.
my question is, how high can i lift the front of my 2011 and still be able to get my alignment within factory specs?
RC 2" is the most used one and cheapest i have and like it a lot. I have but i would much rather have around a 2.25 kit!
thanks for the input everyone. i had an 08 sierra with the sky jacker 2" leveling kit, and my 285/75-16 still rubbed HARD. so i found the 1.5" bottom strut lift and put that in there. that with 3 1/2" rear lift blocks made my truck level, and stopped the rubbing. the problem? it couldnt be aligned, and my tires were cupping BAD.
i have since traded that truck in, and got this 2011 sierra. once this winter is done and i can stop buying heating fuel.... im going to level the beast and put a SI/DO exhaust.
also im leaning towards rough countrys 2" lift because it is one of the least expensive, AND it is a bottom mount lift, so i dont need to remove the struts, and swap sides with them.
    LCH14
    LCH14
  • Who's Online   0 Members, 0 Anonymous, 1,431 Guests (See full list)
