Duuuuuuuuunes then work
I like your duuuuuuuunes photos.
As for my truck...towed the Seadoo down to the lake....love having a truck because if the boat ramp is busy I just back right up to the lake. :thumbs:
Since Saturday I've been going back and forth from old to new house. Last of the big heavy stuff went last night, it's been raining like crazy so I didn't sweat but I was drenched everyday. Just little odds and ends to move then done. Truck is enjoying the towing/hauling. I did sink (all the rain made ground mooshy) in my front yard last night so I have some mild divits to fill once we clear out for good.
Worked in an attic today, miserable 121 degrees
then layed blocks in my yard for a homemade masonary BBQ im making..
'the truck just watched me do all the work'
Funny my wife cleaned our attic today. It was a mess and she was getting rid of baby clothes :)
Ryan
120 in the attic? Hell its supposed to be 105 plus here thurs. lol Work is gonna suck in that heat.
I know the feeling...
Pointed the truck north for about four hours and ended up here:
Drove the truck into work today, STILL acting up because of the Volant. Thought I had it fixed when I fixed the cold start issue by changing all the supplied fittings wit hstronger/better silicone.
Can't seem to get my air/fuel numbers consistent in my logs, they always seem to be different.
Will be swapping out the Volant tube for an AirAir tube when it gets here that is smaller in diameter. Should help the leaning out issues.
Helped move my brother out of my house into his new apartment.
Drove the camaro to get a haircut. I am pulling down 19 mpg in it :)
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,209 Guests (See full list)
