went to the truck/tractor pulls, saw some awesome trucks and it was mostly chevies only 2 fords and some dodges 2 gmcs TORE it up
You been to the dunes recently? I just read that some sort of plane/glider crashed on test hill yesterday.
Drove it to town and got some DEF now just got to add it!! :jester:
Drove to the other side of town to the new Sunoco station, found out they have 93 octane w/o the ethanol in it. My truck is a happy truck now. And all my lawn equipment and my John Deere are going to be happy as well...
apparently it was a husband and wife parasailing they crashed into test hill and both lost their lives, they own the parasailing place out here in shelby.
Edited by SarahsGMC
Prepped and cleaned truck for thunderstorm tomorrow LOL.
In the off chance it doesn't happen then to a car show!
Wow, that is very sad. May they both rest in peace.
went to the fair for the demo derbies, real sad that i didnt get to race and that everyone kept coming up to me asking why i wasnt in the races.. ill be back in next year..
then went out with the boyfriend and the cops were CRAZY we went two tracking then when i took him back to his truck we JUST stopped and a sheriff came flying into the parking lot and shined his light on us wanted to know what we're doing he checked our IDS accused him of being drunk when he wasnt and then let us go.. but waited there until we both pulled out.. then we went downtown and got pulled over again after just passing 3 other cops and a different one pulled me over while he was with me and said he couldnt see my tail lights.. there had to of been like 10 cops cruising around it was nuts!
At first I did this
Then I did this
Followed by this
Finally I wanted to do this
That's cool Brad I really value your opinion let me put it with the rest of the things I don't give a f*** about ;)
Took my neighbor to look at trucks.........
He ended up with a new 2013 Silverado LTZ crew cab with EVERYTHING. Z71 appearance package, deep ruby metallic, GM wheel well liners, GM side steps. GM bed liner, GM tenneau cover, exhaust tip, GM deluxe floor mats. Hello GM, bye bye Ram (gave it to his son)! He loves the Silverado.
Only cost him $40,488
Edited by BlackZ71Silverado
Sent from my ADR6400L using Tapatalk 2
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
