What's the restriction
Sent from my DROID RAZR using Xparent Red Tapatalk 2
There are tons in CA:
Waiting period
<10 round magazine limit
"assault weapon" ban
Difficulty in getting CCW/CPL
General liberalism of the state.
I mean Michigan. I know the restrictions here. I just went thru them
For pistols you need to get a purchase permit from the county sheriff. I don't think they cost anything, it just allows them to do a background check on you. Once issued, it's good for ten days then the pistol gets registered with the state police. There is legislation in the senate now to eliminate the purchase permit and the registry BS and just use the 4473 form.
Hey hey back on topic. No need to get into politics!
Ryan
Ryan
How about this then:
Over the weekend I put the pistols that I think registering is stupid into my truck and drove to the range to shoot then put the pistols that have no business being registered back in my truck and drove home.
Better? :lol:
Edited by MikeNH
Over the weekend is not today! :lol:
A shotgun can double as a shovel when you get stuck on the dunes oooooooo yes I just went there again
Ryan
Today I had the tires rotated and a 265/70R17 tire put on the junkyard wheel I picked up for a spare. It came with a LT245/70R17E. Just trying to prep for my 12 hour drive to Utah on thursday
Took my truck to the dealer to have the side steps looked at beacuse the chrome was starting to tarnish really bad around the plastic pads.
They agreed to replace them under the accesory warranty, even let me take the new ones home today and swap them out myself.
Ryan
Fine-
Today I drove to a customer site in Illinois, a state that also has shitty, useless gun laws judging by the amount of violence in Chicago. And I miss my pistols that are back home which also happen to stupidly be registered to comply with stupid, useless Michigan laws. :P
"Started" my truck but found the battery is on it's last legs. Shopping for a replacement. Wish a could get a deep cycle but the budget committee (the wife) has overruled my request...
Its easier to ask for forgiveness than permission :)
Next time she puts in a requisition for new shoes deny that. Buy the battery and reclaim your manhood
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
