I had the truck loaded with scrap today... was doin some yard cleanup before the snow.. i had an old playset i picked up for free mnths ago and it really wasnt worth holding on to.. So i seperated all the steel from the wood and cut up a little trailer frame that wasnt worth rebuilding or fixing, 720 lbs of metal and got like $70 at the scrap yard.. prices went down there to, Light iron/tin used to be $.10 per per or $10 every 100 lbs, Now its only $7 evry 100 Lbs
You guys must be getting better weather than I am- cold and rainy all day today. But I haven't gone anywhere.
68 here
Ryan
68 here
Ryan
68 here
Ryan
Jeez I'm like 200 miles north and its 20 degrees colder!
Edited by MikeNH
It was 29 at 5-6 am here today in the pocono area, PA
Had to put a heater on in the camper last night, I didnt winterize it yet.
Couldn't tell ya how cold it was at 5:00 this morning. But my bed was nice and warm. :D
I wasnt up... my girlfreind was checking on our daughter and putting wood in the stove and looked at the thermostat..It tells you the outside temp and is normally very close within 1 degree or so.
Ahh. My parents used wood a lot when I was little, always like the smell/"feel" of wood heat. Even if it is a lot of work. :lol: Now I just push buttons on the wall and warm air happens. :lol: Thankfully gas is included in my rent.
It was about 27 degrees here this morning but got up to about 53 today and was sunny until this evening when that rain from Michigan found us..... You know you could have kept the rain! lol
As for the truck all it did today is take me to work and back.
Drove 14 hours home!
Sent from my ADR6400L using Tapatalk 2
"shined some deer" ???
hahaha it means using your headlights or a spot light and putting the beam of light in the deer's eye, this blinds the deer so they normally stand there for a while which makes them easier to shoot...it's highly illegal in the state of sc
Sent from my smartass iPhone using Tapatalk
Edited by GrapeSoda
Pretty sure it's illegal everywhere. haha
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
