Burned $20 worth of premium today
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Put both of them and the car in the garage. Big snow storm coming Wed. morning into Thurs. night. Supposed to get worse and be 3" an hour starting Wed. evening into Thursday night! Going to have a lot of plowing to do.
Sent from my iPhone4S
using Tapatalk
Went and made my payment on my truck during lunch. It's been parked since. Here is the view of my truck from the desk
Dinner with some friends before I start the ride home tomorrow. Just starting to snow.
Took her out in the nice snow we got today. Handled like a champ as usual. Also drove the wife's sorento for the first time in the weather and it also did nicely.
You guys and snow. All I'm getting here is a slight rain. Its pissing me off because I can't catch traction at a stop light.
Bought some new 14ft tie downs. Needed them last week :(
Not today, but on Christmas Eve I got some Weathertech floor mats from my buddy who had ordered them for his 09 Sierra. They didn't fit his truck so he sold them to me they fit fine in my truck.
Sent from my DROID RAZR using Tapatalk 2
Been watching my voltage slowly drop @ full charge for a month so I bought a new alternator and belts. Cleaned the battery terminals and replaced the alternator. Then the body control module decided to give up the ghost when I plugged everything back up. New BCM and programming @ the dealer cost $483. The new alternator & belts were $256. This all happened on the day the world was ending 12/21
Sent from my Galaxy Nexus using Tapatalk 2
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
