I joined a year ago. I just fixed my my denali headlight housing. A little epoxy and its good as new
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
I get all warm and fuzzy inside when I look at this :D
Sent from your truck via Tapatalk
Not much likely. Work from home today and it'd cold out so I'll be a wuss and stay home and make lunch here. :lol: Drove back from the airport yesterday, had some good BBQ in Ann Arbor then back home to dump the work stuff and grab the HK to take it to the range and try out the new trigger. Shoots nice! And my order of .45 ammo will be here Monday which is nice cause I'm about out. UPS guy must hate me, this is the third box of mail order ammo in a few months and the .45 is by far the heaviest- 42 pounds (1000 rounds).
Sarah, did your light bar get messed up by the deer?
Not at all :D
That's a good spot for that Ryan. Exactly where I put my 6.2L badge.
Sent from my Samsung Galaxy S3
Edited by Daryl NHT
Since it was around 40 degrees today I changed the oil in both the Sierra and Equinox with some fresh Mobil 1 !!!!
Washed it up. Man I have rail dust spots bad I cant wait till spring to claybar it. Why did I get a white truck again?
Sent from my SCH-I535 using Tapatalk 2
Took the truck into the mountains today. Not much snow suprisingly. But it was a beautiful day out in Southern Colorado today!
-Ben
Nice pics Ben. That rock in pic 2 would have made me nervous, even if it hasn't moved in a couple of million years.
Thanks. And yeah my fiance didn't like it at all!
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
