I drive the truck there. It made a bad rattle on the drive too
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Now I'm pretty sure I lost a cat.
You weren't watching hockey? Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Pfft! Nope we do leave our igloos up here once and a while and watch something else. LOL
I knew you guys had igloos. And I was called a bigot for thinking that before.
Trying to figure out how to wire up my Battery Tender
To? I have one on my camaro
Ryan
Just finished my platform for my new 64 gun garage safe. Had a hell of a time getting it up on the pad.ImageUploadedByTapatalk1361911795.251082.jpg
Sent from my iPhone4S
using Tapatalk
Did you bolt it down? And is there a particular purpose for the raised base?
looks like hes keeping it off the concrete floor guessing to prevent rust
Sent from my SCH-I535 using Tapatalk 2
I just picked my 2012 GMC Sierra 5.3L C1500 crew up from the muffler shop this afternoon,
The Borla- GMPP Sport muffler is on. The shop only charged me $40.00 to weld her up & add a new head-pipe.
Can't wait for the drive home tonight.... :driving:
using Tapatalk
Will be bolting it down later tonight. The raised base is to keep water contact to a minimum. I wash my vehicles in my garage and when I wash the floor, it wont get wet.
using Tapatalk
Have you installed a drain in the garage floor to help minimize it as well? Just something I'm curious about. I wish I had the cash for a safe that nice.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
