Seems like a nice setup.
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Went for a quick drive to grab dinner. Then nearly hit someone who stopped in the middle of the intersection to let someone in the opposing land make an illegal turn. With the roads as slippery as they are it's amazing I didn't hit her.
People all day everyday keep asking me details about how I'm doing the lift
Sent from your truck via Tapatalk
I didn't drive today. I spent the day searching for cats because one of mine went south and no code as to which one
That would be a non issue if you lived here. You could fix it with a set of LT headers. Which I'm considering doing, since that way I wouldn't have to retune, I could install them before the tune. Hmmm
I am going to do mid-lengths. But current concern is the cats and a corsa sport
Would Pacesetter LT's be a good setup? I'm not sure whether they would be worth it. I'd also have to make them work on my current exhaust.
Edited by kstruckcountry
You would probably have to get their Y-pipe. But a lot of guys use them
Stacks and roll coal
I'll think about it. Tires+Intake Tube+Tune= tons of money. Not sure I want to add to that. :nonod: Maybe I'll wait until cats crap out
if you have over 100k, your cat most likely dosent have too much life left. i needed a cat at 110k and 90k on my old silvy
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
