Damn its even got an LBZ, slick looking truck. Be better with a solid front axle
yea it, that thing was so sick! It actually had a BDS lift kit on it, no solid axle
did the 32" mod, joined the 32" dump club, and no change to my exhaust sound.........oh well.......
Well it was actually a month ago now, but I finally got some new tires on the truck. This time I went with Firestone Destination LE2's. The previous AT's were great but I've calmed down a bit so I went with something a little more appropriate for the roads I drive on. So far I've got 2k miles on them and they are really quiet and wearing great...now that my alignment has been done again.
Weather permitting I've got to readjust my front left fender tomorrow. Somehow that deer I hit knocked it forward and it's causing some bad rubbing.
I will probably be picking up my AFE intake and exhaust on Monday. Hope to have it installed over the Christmas break. Also ordered my Rough Country Leveling Kit. Hopefully it'll arrive before the end of the year. Hopefully I can order my wheels in February when Ray's releases them (no more 5 step forging on the TE37X. Going to a 3 step forging on the new TE37X Ultra).
Got my tires rotated and saw this sweet dmax on 40s thereeqarugar.jpga2abuze3.jpgy9y5a3y8.jpg
Sent from my smartass iPhone using Tapatalk
needs an alignment badly
Tomorrow hauling my new camaro rims to the shop to have tires mounted :)
Ryan
Took my truck vehicle shopping for the wife, she ended up getting a new Equinox LTZ. Will be here Tuesday.
They are factory reproduction ZL1/1LE rims. 20x9 fronts and 20x10 rears. Much cheaper than the gm version but look the same :)
Ryan
Edited by RyanbabZ71
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,209 Guests (See full list)
