Those wheels are fatter than the fenders. I'm waiting for it to turn into a decepticon!!
Sent from my DROID RAZR HD
Took it out to the Home & Garden show to explore some ideas for a deck or patio
Go with the composite decking Ryan
isn't that the once orange display the hotwheels camaro debuted on?
Not see looks similar Ryan
Used to mold the little a caps for composite decking seems pretty cool and easy to own
Drove to the store to get a few things but forgot my wallet so thst was a waste... so I changed my oil in record time.
sent from my truck in a field
Edited by SarahsGMC
I want the yellow one....I'll give up my truck for that car and even include my dad's 2000 stepside silverado then end up sharing it with him when he's home
A black debadged 6s 5 door would look greatSent from my SM-N900V using Tapatalk
NLA in the US. 6s or the 5 door. No more V6s. Guess they figured MPG was bigger seller than quickest mid size. (Wasn't for me, lol, happy with my 3.7L)
Edited by SnakeEyes
NLA in the US
What? My friend, old roommate, and current member had an 08 6s 5 door in black. Traded it for his 06 silverado
What? My friend, old roommate, and current member had an 08 6s 5 door in black. Traded it for his 06 silveradoSent from my SM-N900V using Tapatalk
Yeah....Gen 1. We are on Gen three now.
Ok? I just stated that the combo I specified would look great.
Ok? I just stated that the combo I specified would look great. Sent from my SM-N900V using Tapatalk
Thought you were talking about a new model. Those 1st gen can be had dirt cheap now. Awful resale value. My 2nd gen fared a little better, but I knew going in so I'm not too upset, didnt buy to resell
Edited by SnakeEyes
Yea. In 2010 he didnt get much for his on trade
Makes no sense, what would be my daily driver :lol:
This guy forgets why Cars are made
:lol:
You would have so much fun in the process. THAT is why you spend money, once your needs and nesessities are covered
Edited by SnakeEyes
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
