It's alive!
Sent from my LG-D800 using Tapatalk
Took the younger pup for a ride in the truck for the first time now that I sold dad's old Buick that I used to cart them around in.
Ok update on the Bilstein 5160's I installed up front. They are wayyy better than the white body shocks that came with my lift kit. I also cranked down an inch so I'm sure that had something to do with it. Overall I don't think I even needed the 5160's I could have gone with 5100's but oh well. These things ride smooth and makes me like driving my truck even more
Sent while cruising down a back road...
I was going to go with the 5100's on my truck, but I already had two Rancho's for on the back so I'm going with them.
Bilstein is definitely one of the tops. I was considering Fox shocks but I heard Bilstein were smoother. Nice thing about the fox's though is they are completely rebuildable
I think 5160's are sweet, I want some. I think Ranchos quality is not very good compared to the Steins.
I don't doubt that. There's a reason that Rancho's cost $35 less per shock than the 5100's.
Bilstein used to run ads in magazines saying while most shocks start to die around 80K miles, Bilstein are still at 70% around then.
Changed the oil and replaced both front wheel speed sensors on my wife's Yukon Denali XL... Drove my truck to get the parts for the job.
Got the new steering wheel in. Need a new airbag to match it now
Edited by Chris
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
