Your probably right, but they didn't teach cell phone recording in first responder or firefighter classes. Lol
Sent from my LGL86C using Tapatalk
Took the family out to eat tonight and a guy went down outside. Rolled him over to find no pulse. Started cpr and by the time they loaded him in the ambulance he was starting to talk. Best feeling ever!
Great job! Edited by RyanbabZ71
I didn't use the breaks I was angry as all hell and stomped on it im surprised it did that to be honest
Hit dunes with a friend today 76 ford with a 12v cummins very clean setup we were on test hill in this pic
Edited by SarahsGMC
Didn't know Cummins was making 12 volt motors? I thought Power Wheels was the only one? Learn something new every day.
Sorry, couldn't resist.
Spent a lot of time at the dunes back in the 70's. Back when that '76 was a new one!
Seen any new 14's out there putting around? Not sure if my factory tires would even get me on the dunes?
Edited by Ventilator
Yea there's a few 14s that been out there and yea factory tires will do fine out there less aggressive tread the better
Hauled the quads to a friends house to ride yesterday
Gonna skeet shoot out his back yard now. Good weekend!!
Sent while in 'Murica...
Not so worried about the tread, more about if I could let enough air out for a good footprint? These new tires are a lot different construction than the tires were 35+ years ago.
We could go down to 8 psi, not sure about these new tires? I have 265 65 18's, so they should do better than the 20's and 22's?
Just been out if the loop for too long, but I have an old Silver Lake flag out in the barn. LOL
I changed the brake light switch in the 2011 F150 and had to get the boat running again. Going to have to do heavy transom repair.
Thanks for the info. Back in the day, it was mostly 15" rims. Some 16" and 16.5".
Got off early and took her fishing. Went to a creek and lake but didn't catch anything. Went to my buddies pond right up the street and caught 3 smallmouth and 3 largemouth. Haven't caught a fish out of that pond in a couple years. Two of the largemouth were nice size. Scratched the paint up running through tall grass. Not too worried about it
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
